03-06-2013 12:36 PM - edited 03-16-2019 04:06 PM
Hello All,
I have a Helios 2n panel which is working well on CUCME. MY only issue is we have setup an XML string to be able to allocate a button on the 9951 to trigger a gate release. All works fine until you reboot. The string has a ? in it and as such on reboot it treats it as a help.
voice register template 1
url-button 1 http://10.117.101.10/enu/lockstate.xml.p?lock1state=1 GRV Gate
Can anyone advise how to enable the ? to be entered in the string as the config is loaded? We've tried ^v (ctl V) but to luck.
Kindest Regards
David
03-07-2013 03:13 AM
Does anyone have any idea on how to enter the Ascii character decimal or hex for ? (question mark)
04-12-2013 08:13 AM
Hello All,
Anyone got any idea on this? Still can't work out how to enter a ascii character command in the config file to paste to the router. Both in the Dyndns and XML string I have this problem for the "?" character.
David
04-13-2013 01:43 PM
The only way is typing ^V before the special character. If that doesn't work, there is a bug.
04-24-2013 05:35 AM
Hi paolo,
I need to be able to use the ASCII string in the config and not ^V. The issue is that when the router reboots the ? That was in the config stops the XML string from completing
David
