11-19-2012 07:27 AM - edited 03-16-2019 02:16 PM
I have Call Manager 4.1 . I need to get the XMLDefault.CNF file from Call Manager server .How do I get that ?
Please help.
regds,
aman
Solved! Go to Solution.
11-19-2012 09:26 AM
Hi Aman,
Yes, thats correct. Follow the command I mentioned to pull the xmldefault.cnf.xml file from the TFTP server.
Harmit.
11-19-2012 08:18 AM
Hi Aman,
Install tftpd32(or tftpd64)on your computer. you can download it from the following link :
http://tftpd32.jounin.net/tftpd32_download.html
1)Launch tftpd32
2)Click on "Tftp Client" tab
3)put in the Call Manager TFTP IP address in the "Host" field
4)Put "xmldefault.cnf.xml" in the "Local File" field and click "Get".
This will download the config file in the directory used by tftpd32.
I have a screenshot of tftpd64 from my computer which runs on a 6 bit OS :
Hope this helps!
Saurabh
12-03-2015 04:01 PM
Hi guys,
Could there be a reason why nothing seems to be coming up for me? I've tried both commands through cmd on windows vista ultimate as well as with this program above mentioned by Saurabh. I can ping my cisco tftp 10.1.1.1 on command prompt. Any ideas? Thanks in advance.
11-19-2012 08:29 AM
Hi Aman,
Open command prompt on your laptop / PC. Run the following command:
tftp
Example:
C:\>tftp 10.104.149.118 get XMLDefault.CNF.XML
Transfer successful: 7332 bytes in 1 second, 7332 bytes/s
Please rate if this helps.
Harmit.
11-19-2012 08:50 AM
Thanks for reply.
One more query from where do we get XMLDefault.CNF file in call manager or I simply follow the above procedure to download the XMLDefault file and then,edit for desired firmware version.
regds,
aman
11-19-2012 09:06 AM
Hey Aman,
That file like all phone config files is stored in the system memory of the TFTP server. The best way to download it would be the procedure described above.
HTH,
Harmit.
11-19-2012 09:19 AM
Hi Harmit,
Are these configuration files IP phone model dependent?
If I simply follow the procedure as mentioned by you, would I be able to download the XMLDefault.cnf file.
regds,
aman
11-19-2012 09:26 AM
Hi Aman,
Harmit.
11-19-2012 09:38 AM
Hi Harmit,
I would do this tomorrow and let u know.
regds,
aman
11-27-2012 09:18 AM
Hi Harmit,
Thanks for support.
regds,
aman
11-27-2012 09:24 AM
Glad I could help Aman! See you around :-)
Harmit.
06-01-2020 10:18 AM
07-25-2021 07:50 AM
I am facing the same problem. Did you found a solution for your problem.
