Compatibility checks on CUCMV11 and Polycom Kirk Dect server
S N
Experts,
I am not sure whether I can post this here.
One of our customer is using CUCM Version 7 interated with Polycom Kirk Dect V6000 server ad now planning to migrate to CUCM V11.
Is anyone can provide me a compatibility guide to check if CUCM V11 supports their current Polycom version.
If anyone got the integration guide please share it with me.
Sathya
Jaime Valencia
Cisco doesn't perform any kind of testing with 3rd party endpoints, if they run SIP, they *might* be configured as SIP 3rd party devices, if the vendor performs any kind of testing, they'll be the ones posting the info
http://support.polycom.com/PolycomService/support/us/support/strategic_partner_solutions/solutions_cisco.html
java
if this helps, please rate
Gordon Ross
Level 9
Level 9
If you're running the Kirk system as a third-party SIP it should work. I've got my Kirk system running as native registeration and that's working fine on CUCM 11.0
GTG
Please rate all helpful posts.
