Conection problems in a network with a webserver and 4 hosts IPv6
etroncho555
Hello everyone !
 I can not send a paquet among the server and anyone of the hosts, neither among hosts
Thanks a lot
Martin L
I guess u did a typo error, FDEE instead of just DEE ?  PC 2 and 3 can ping PC0;  Server IP is FDEE:1413:6B37:F522::1, PC0 is DEE:1413:6B37:F522::2;  PC1 is DEE:1413:6B37:F522::3, etc Network address is different;  PCs are on different subnet, which means u need some sort of L3 device to do routing.
Regards, ML
**Please Rate All Helpful Responses **
Hi Martin,
You are right Martin, i have an error with the ips, but still i can not conect with the diferent devices.
I do not have an idea why
ping works if you ping from CMD of PC but not from PT GUI feature; open PC 0 CMD window and type in
ping FDEE:1413:6B37:F522::5
you should get
Pinging FDEE:1413:6B37:F522::5 with 32 bytes of data:
Reply from FDEE:1413:6B37:F522::5: bytes=32 time=1ms TTL=128
Reply from FDEE:1413:6B37:F522::5: bytes=32 time<1ms TTL=128
Regards, ML
Hi Martin,
I did it like you coment and works.
I am usin the free Packet Tracert version 8.1.1.0022 and i think it works worse than others before.
Thanks Martin.
