IPv6 compatibility with CISCO ACE 4710 load balancer
tuhinbhowmick
We are having Cisco ACE 4710 K9 load balancer with version A3(2.7) on our environment. Now we have to migrate our Ipv4 network infrastructure to IPv6. So, can any one confim us that whether Cisco ACE 4710 K9 load balancer with our version is IPv6 compatible ?
Also, the latest IOS version of ACE 4710 loadbalancer is A4(2.1a). So, if we upgrade the version then whether we will be able to use it for IPv6 ?
Looking forward to your expert opinion.
Tuhin
Phillip Remaker
Which IPv6 functions do you plan to use?  Are you running native IPv6 or do you intent to make the IPv6 infrastructure appear as IPv4?
This disucssion may help: https://supportforums.cisco.com/thread/2054982
