module supported
SaeedBakh_2
dear,
we have 7606 chassis with SUP720-B
is the bellow modules will support IPv6 and let me know if there is any limitation for IPv6 for the bellow modules:
1)
WS-X6724-SFPCatalyst 6500 24-port GigE Mod: fabric-enabled (Req. SFPs)
WS-X6748-SFPCatalyst 6500 48-port GigE Mod: fabric-enabled (Req. SFPs)
2)
WS-X6704-10GECat6500 4-port 10 Gigabit Ethernet Module (req. XENPAKs)
3)
WS-SVC-FWM-1-K9Firewall blade for 6500 and 7600, VFW License Separate
WS-SVC-IDS2-BUN-K9600M IDSM-2 Mod for Cat
thank you in advance
Phillip Remaker
The line cards should support IPv6 without any trouble,
FWSM has some IPv6 support, but IPv6 may cause higher CPU usage on the FWSM:
http://www.cisco.com/en/US/partner/products/hw/modules/ps2706/products_qanda_item09186a00801e9e26.shtml
IDSM-2 does not have IPv6 support.  http://www.cisco.com/en/US/prod/collateral/vpndevc/ps5729/ps5713/ps4077/ps9157/product_bulletin_c25-504716_ps2113_Products_Bulletin.html
