IPV6 LAN not routing to WAN
exulan
My router is able to ping the internet via IPV6
exulanit-router#ping 2606:4700:4700::1111
Sending 5, 100-byte ICMP Echos to 2606:4700:4700::1111, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/2 ms
My devices can ping the router IPV6 address
exulan@server1:~$ ping 2001:DB8:85A3:1::1
PING 2001:DB8:85A3:1::1(2001:db8:85a3:1::1) 56 data bytes
64 bytes from 2001:db8:85a3:1::1: icmp_seq=1 ttl=64 time=3.27 ms
64 bytes from 2001:db8:85a3:1::1: icmp_seq=2 ttl=64 time=0.700 ms
64 bytes from 2001:db8:85a3:1::1: icmp_seq=3 ttl=64 time=0.695 ms
64 bytes from 2001:db8:85a3:1::1: icmp_seq=4 ttl=64 time=0.657 ms
But my devices cannot ping the internet via IPV6
exulan@server1:~$ ping 2606:4700:4700::1111
PING 2606:4700:4700::1111(2606:4700:4700::1111) 56 data bytes
^C
--- 2606:4700:4700::1111 ping statistics ---
22 packets transmitted, 0 received, 100% packet loss, time 21491ms
Ive been looking into this for hours but cannot get it to work.
This is my full running-config
https://termbin.com/45ep
Harold Ritter
Hi @exulan ,
Using the documentation prefix "2001:db8::/32" will not work. You need to use a routable prefix.
You can use DHCPv6 prefix delegation to get a prefix from the ISP. Try the following configuration.
interface GigabitEthernet0/0/0
 ipv6 address dhcp
 ipv6 address autoconfig default
ipv6 dhcp client pd prefix-from-provider
interface GigabitEthernet0/0/1
ipv6 address prefix-from-provider ::1:0:0:0:1/64
12 Replies 12
balaji.bandi
 ip address dhcp
 ip nat outside
 media-type rj45
 negotiation auto
 ipv6 address dhcp
what is the IP address you get from ISP  IPV6 or IPV6  - based on that you need to have NAT
if you getting IPv4 you need NAT64 translation required.
also check default route you getting from DHCP ?
check some NAT64 examples :
https://www.cisco.com/c/en/us/support/docs/ip/network-address-translation-nat/217208-understanding-nat64-and-its-configuratio.html
BB
Harold Ritter
Hi @exulan ,
 ipv6 address dhcp
Thank you, ipv6 internet connectivity its now working on devices connected to my g0/0/1 interface but the devices on the vlan 88 g0/0/1.88 interface are not getting an IPV6 address.
ipv6 unicast-routing
ipv6 dhcp pool Server_Network_IPV6
prefix-delegation pool prefix-from-provider
dns-server 2606:4700:4700::1111
ipv6 dhcp pool Main_Network_IPV6
ipv6 address dhcp
ipv6 enable
ipv6 address prefix-from-provider ::15:1/64
ipv6 enable
ipv6 dhcp server Main_Network_IPV6
interface GigabitEthernet0/0/1.88
encapsulation dot1Q 88
ipv6 address prefix-from-provider ::88:1/64
ipv6 enable
ipv6 dhcp server Server_Network_IPV6
Hi @exulan ,
I am glad to hear it is now partially working.
You have both gi0/0/1 and gi0/0/1.88 using the same /64 at the moment (prefix-from-provider ::/64), hence it does not work for gi0/0/1.88.
Try the following instead:
int gi0/0/1
ipv6 address prefix-from-provider ::15:0:0:0:1/64
int gi0/0/1.88
ipv6 address prefix-from-provider ::88:0:0:0:1/64
Can you also provide the output for "show ipv6 general-prefix"?
exulanit-router(config-subif)#do show ipv6 general-prefix
IPv6 Prefix prefix-from-provider, acquired via DHCP PD
2403:5814:F0B1::/48 Valid lifetime 5719, preferred lifetime 2118
GigabitEthernet0/0/1 (Address command)
GigabitEthernet0/0/1.88 (Address command)
exulanit-router(config-subif)#do show ipv6 int gi0/0/1.88
GigabitEthernet0/0/1.88 is up, line protocol is up
IPv6 is enabled, link-local address is FE80::56A2:74FF:FE64:CA61
No Virtual link-local address(es):
General-prefix in use for addressing
No global unicast address is configured
Joined group address(es):
FF02::1
FF02::2
FF02::1:2
FF02::1:FF64:CA61
FF05::1:3
MTU is 1500 bytes
ICMP error messages limited to one every 100 milliseconds
ICMP redirects are enabled
ICMP unreachables are sent
ND DAD is enabled, number of DAD attempts: 1
ND reachable time is 30000 milliseconds (using 30000)
ND advertised reachable time is 0 (unspecified)
ND advertised retransmit interval is 0 (unspecified)
ND router advertisements are sent every 200 seconds
ND router advertisements live for 1800 seconds
ND advertised default router preference is Medium
Hosts use stateless autoconfig for addresses.
Hi @exulan ,
The issue is exactly what I explained in my previous post. gi0/0/1.88 does not have an ipv6 address because ::15:1 and ::88:1 are actually part of the same /64, hence gi0/0/1.88 not being configured with a global unicast ipv6 address.
The following should work for you:
int gi0/0/1
int gi0/0/1.88
So I changed it to what you said and it still wasnt working, All devices lost connectivity to the internet via ipv6
ipv6 enable
ipv6 nd autoconfig prefix
ipv6 enable
So I did this
ipv6 enable
ipv6 address 2403:5814:F0B1:88::1/64
ipv6 enable
and now everything is working! Thank you for your help.
Hi @exulan ,
The configuration you provided is static and might not work over time.
Can you please provide a "show ipv6 int gi0/0/1" and "show ipv6 int gi0/0/1.88" with the configuration I provided?
I see, I reverted it back to what you recommended.
exulanit-router#show ipv6 int gi0/0/1
GigabitEthernet0/0/1 is up, line protocol is up
Global unicast address(es):
2403:5814:F0B1:15::1, subnet is 2403:5814:F0B1:15::/64 [CAL/PRE]
valid lifetime 7077 preferred lifetime 3476
FF02::1
FF02::2
FF02::1:2
FF02::1:FF00:1
FF02::1:FF64:CA61
FF05::1:3
MTU is 1500 bytes
exulanit-router#show ipv6 int gi0/0/1.88
2403:5814:F0B1:88::1, subnet is 2403:5814:F0B1:88::/64 [CAL/PRE]
valid lifetime 7068 preferred lifetime 3467
FF02::1
FF02::2
FF02::1:2
FF02::1:FF00:1
FF02::1:FF64:CA61
FF05::1:3
MTU is 1500 bytes
Hi @exulan ,
This looks good. Both gi0/0/1 and gi0/0/1.88 have their own /64. Can you test again to check that it works.
MY BAD! I had to renew the ipv6 release on the device to get it to work, my apologies for that. Its all working now thank you!
Hallo,please support and share for me access back ipV6 network Cisco Group.
