11-01-2017 07:01 AM
We use AXL API in our application to do 2 things:
a) Retrieve the list of devices using the SOAP WSDL at /axl:8443
b) Once the devices are retrieved, we send a set of SOAP requests to /realtimeservice/services/RisPort:8443 to get the IP addresses of registered phones. In order to do so, we open a socket, write a request made up of 100 devices, get the response, parse it and store the IP. We iteratively do this until all the devices are sent in the request for their IP. In between each request, we make the thread sleep for 5 seconds as Cisco CUCM suggests up to a max of 12 requests per minute. In case the request/response reports any kind of error, our application raises an alarm. Despite an alarm being raised, application still continues to send further requests until all the devices are covered for their IP addresses.
All goes well until one of our customer reported the alarm raised by our application. The alarm indicates that the application could not get the IP address of the devices in one of the requests. Looking at the logs, we came to realize that the CUCM returns "ArrayIndexOutOfBoundsException" in the SOAP response. I am pasting the response here. I am also pasting a working SOAP response. The subsequent request (with the next set of 200 devices) works fine. My point is that the erroneous SOAP response happens occasionally and we are not able to figure out the cause of it. Any help will be much appreciated. Our SOAP request is always made of 200 devices.
Here is the SOAP response:
2017-08-26T08:02:18,089 [pool-4-thread-1] I - <?xml version="1.0" encoding="UTF-8"?>
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<soapenv:Body>
<soapenv:Fault>
<faultcode>soapenv:Server.userException</faultcode>
<faultstring>java.lang.ArrayIndexOutOfBoundsException: 21</faultstring>
<detail><ns1:stackTrace xmlns:ns1="http://xml.apache.org/axis/">
at com.cisco.ccm.serviceability.soap.risport.RisBindingImpl.selectCmDevice(Unknown Source)
at com.cisco.ccm.serviceability.soap.risport.RisBindingSkeleton.selectCmDevice(Unknown Source)
at sun.reflect.GeneratedMethodAccessor309.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.java:397)
at org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:186)
at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:323)
at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454)
at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281)
at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:699)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:646)
at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
at com.cisco.vos.platform.tomcat.valves.CiscoResponseHeaderFilter.doFilter(Unknown Source)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:610)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:950)
at org.apache.catalina.authenticator.SingleSignOn.invoke(SingleSignOn.java:312)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1040)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:607)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:313)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:895)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:918)
at java.lang.Thread.run(Thread.java:682)</ns1:stackTrace><ns2:hostname xmlns:ns2="http://xml.apache.org/axis/">orlphcm01</ns2:hostname>
</detail>
</soapenv:Fault></soapenv:Body></soapenv:Envelope>
Working SOAP response:
<?xml version="1.0" encoding="UTF-8"?><soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<soapenv:Body><ns1:SelectCmDeviceResponse soapenv:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:ns1="http://schemas.cisco.com/ast/soap/">
<SelectCmDeviceResult xsi:type="ns1:SelectCmDeviceResult">
<TotalDevicesFound xsi:type="xsd:unsignedInt">45</TotalDevicesFound>
<CmNodes soapenc:arrayType="ns1:CmNode[6]" xsi:type="soapenc:Array" xmlns:soapenc="http://schemas.xmlsoap.org/soap/encoding/"><item xsi:type="ns1:CmNode">
<ReturnCode xsi:type="ns1:RisReturnCode">NotFound</ReturnCode>
<Name xsi:type="xsd:string">172.27.192.10</Name><NoChange xsi:type="xsd:boolean">false</NoChange><CmDevices soapenc:arrayType="ns1:CmDevice[0]" xsi:type="soapenc:Array"/></item><item xsi:type="ns1:CmNode"><ReturnCode xsi:type="ns1:RisReturnCode">Ok</ReturnCode><Name xsi:type="xsd:string">172.27.192.164</Name><NoChange xsi:type="xsd:boolean">false</NoChange><CmDevices soapenc:arrayType="ns1:CmDevice[12]" xsi:type="soapenc:Array"><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEPDUKESK</Name><IpAddress xsi:type="xsd:string">141.240.175.135</IpAddress><DirNumber xsi:type="xsd:string">68012-UnRegistered</DirNumber><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">30016</Model><Product xsi:type="xsd:unsignedInt">30041</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string">dukesk</LoginUserId><Status xsi:type="ns1:CmDevRegStat">UnRegistered</Status><StatusReason xsi:type="xsd:unsignedInt">6</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">2</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string">King Dukes - 68012 - 68012</Description><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1503506160</TimeStamp></item><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEPF02572799F06</Name><IpAddress xsi:type="xsd:string">172.27.248.134</IpAddress><DirNumber xsi:type="xsd:string">75621-Registered</DirNumber><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">435</Model><Product xsi:type="xsd:unsignedInt">334</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string">e337839</LoginUserId><Status xsi:type="ns1:CmDevRegStat">Registered</Status><StatusReason xsi:type="xsd:unsignedInt">0</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">2</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string">Julian Finlaw - 75621</Description><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1503694584</TimeStamp></item><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEP64168D5008BE</Name><IpAddress xsi:type="xsd:string">172.27.174.102</IpAddress><DirNumber xsi:type="xsd:string">67351-Registered</DirNumber><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">435</Model><Product xsi:type="xsd:unsignedInt">334</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string" xsi:nil="true"/><Status xsi:type="ns1:CmDevRegStat">Registered</Status><StatusReason xsi:type="xsd:unsignedInt">0</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">2</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string">James Mashburn - 67351</Description><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1503417589</TimeStamp></item><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEPF02572798B98</Name><IpAddress xsi:type="xsd:string">172.27.185.78</IpAddress><DirNumber xsi:type="xsd:string">62777-Registered</DirNumber><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">435</Model><Product xsi:type="xsd:unsignedInt">334</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string" xsi:nil="true"/><Status xsi:type="ns1:CmDevRegStat">Registered</Status><StatusReason xsi:type="xsd:unsignedInt">0</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">2</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string">Jesse Peinado - 62777</Description><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1503606337</TimeStamp></item><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEPF09E630FC225</Name><IpAddress xsi:type="xsd:string">172.27.201.214</IpAddress><DirNumber xsi:type="xsd:string">67999-Registered</DirNumber><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">435</Model><Product xsi:type="xsd:unsignedInt">334</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string" xsi:nil="true"/><Status xsi:type="ns1:CmDevRegStat">Registered</Status><StatusReason xsi:type="xsd:unsignedInt">0</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">2</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string">Kyle Gesualdi - 67999</Description><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1503325449</TimeStamp></item><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEP64168D50077D</Name><IpAddress xsi:type="xsd:string">172.27.176.81</IpAddress><DirNumber xsi:type="xsd:string">66533-Registered</DirNumber><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">435</Model><Product xsi:type="xsd:unsignedInt">334</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string" xsi:nil="true"/><Status xsi:type="ns1:CmDevRegStat">Registered</Status><StatusReason xsi:type="xsd:unsignedInt">0</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">2</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string">Vince Davila - 66533</Description><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1503607184</TimeStamp></item><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEP189C5DB79C32</Name><IpAddress xsi:type="xsd:string">172.27.170.155</IpAddress><DirNumber xsi:type="xsd:string">60779-Registered</DirNumber><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">435</Model><Product xsi:type="xsd:unsignedInt">334</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string" xsi:nil="true"/><Status xsi:type="ns1:CmDevRegStat">Registered</Status><StatusReason xsi:type="xsd:unsignedInt">0</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">2</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string">Alex Jean-Gilles - 60779</Description><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1500648229</TimeStamp></item><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEPE8EDF3AA0428</Name><IpAddress xsi:type="xsd:string">172.27.190.92</IpAddress><DirNumber xsi:type="xsd:string">63463-Registered</DirNumber><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">436</Model><Product xsi:type="xsd:unsignedInt">335</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string" xsi:nil="true"/><Status xsi:type="ns1:CmDevRegStat">Registered</Status><StatusReason xsi:type="xsd:unsignedInt">0</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">2</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string">Louis Saparito - 63463 - TSG</Description><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1500648732</TimeStamp></item><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEPF0257279861A</Name><IpAddress xsi:type="xsd:string">172.27.181.73</IpAddress><DirNumber xsi:type="xsd:string">60625-Registered</DirNumber><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">435</Model><Product xsi:type="xsd:unsignedInt">334</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string" xsi:nil="true"/><Status xsi:type="ns1:CmDevRegStat">Registered</Status><StatusReason xsi:type="xsd:unsignedInt">0</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">2</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string">Joel Yello - 60625</Description><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1503615799</TimeStamp></item><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEPF0257279EEFF</Name><IpAddress xsi:type="xsd:string">141.240.197.134</IpAddress><DirNumber xsi:type="xsd:string">61119-Registered</DirNumber><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">435</Model><Product xsi:type="xsd:unsignedInt">334</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string" xsi:nil="true"/><Status xsi:type="ns1:CmDevRegStat">Registered</Status><StatusReason xsi:type="xsd:unsignedInt">0</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">2</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string">Kip Lutz - 61119</Description><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1503006118</TimeStamp></item><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEP1CDEA782B1C2</Name><IpAddress xsi:type="xsd:string">172.27.187.52</IpAddress><DirNumber xsi:type="xsd:string">61127-Registered</DirNumber><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">435</Model><Product xsi:type="xsd:unsignedInt">334</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string" xsi:nil="true"/><Status xsi:type="ns1:CmDevRegStat">Registered</Status><StatusReason xsi:type="xsd:unsignedInt">0</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">2</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string">Lab - 61127</Description><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1500648735</TimeStamp></item><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEPB41489A223B5</Name><IpAddress xsi:type="xsd:string">172.27.200.139</IpAddress><DirNumber xsi:type="xsd:string">66797-Registered</DirNumber><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">435</Model><Product xsi:type="xsd:unsignedInt">334</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string" xsi:nil="true"/><Status xsi:type="ns1:CmDevRegStat">Registered</Status><StatusReason xsi:type="xsd:unsignedInt">0</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">2</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string">Kevin Glidewell - 66797</Description><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1500648236</TimeStamp></item></CmDevices></item><item xsi:type="ns1:CmNode"><ReturnCode xsi:type="ns1:RisReturnCode">NotFound</ReturnCode><Name xsi:type="xsd:string">172.27.192.8</Name><NoChange xsi:type="xsd:boolean">false</NoChange><CmDevices soapenc:arrayType="ns1:CmDevice[0]" xsi:type="soapenc:Array"/></item><item xsi:type="ns1:CmNode"><ReturnCode xsi:type="ns1:RisReturnCode">Ok</ReturnCode><Name xsi:type="xsd:string">172.27.192.9</Name><NoChange xsi:type="xsd:boolean">false</NoChange><CmDevices soapenc:arrayType="ns1:CmDevice[16]" xsi:type="soapenc:Array"><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEPECC882B128D7</Name><IpAddress xsi:type="xsd:string">172.27.138.117</IpAddress><DirNumber xsi:type="xsd:string">52534-Registered</DirNumber><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">435</Model><Product xsi:type="xsd:unsignedInt">334</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string" xsi:nil="true"/><Status xsi:type="ns1:CmDevRegStat">Registered</Status><StatusReason xsi:type="xsd:unsignedInt">0</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">2</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string">Joseph Vitale Joseph - 52534</Description><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1503069934</TimeStamp></item><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEPDUKESK</Name><IpAddress xsi:type="xsd:string">141.240.229.194</IpAddress><DirNumber xsi:type="xsd:string">68012-UnRegistered</DirNumber><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">30016</Model><Product xsi:type="xsd:unsignedInt">30041</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string">dukesk</LoginUserId><Status xsi:type="ns1:CmDevRegStat">UnRegistered</Status><StatusReason xsi:type="xsd:unsignedInt">6</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">2</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string">King Dukes - 68012 - 68012</Description><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1503519057</TimeStamp></item><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEP64168D506439</Name><IpAddress xsi:type="xsd:string">172.27.174.135</IpAddress><DirNumber xsi:type="xsd:string">63802-Registered</DirNumber><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">435</Model><Product xsi:type="xsd:unsignedInt">334</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string" xsi:nil="true"/><Status xsi:type="ns1:CmDevRegStat">Registered</Status><StatusReason xsi:type="xsd:unsignedInt">0</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">2</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string">Frederick Shamieh#2 - 63802</Description><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1500648534</TimeStamp></item><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEPF02572799F06</Name><IpAddress xsi:type="xsd:string">172.27.248.134</IpAddress><DirNumber xsi:type="xsd:string" xsi:nil="true"/><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">435</Model><Product xsi:type="xsd:unsignedInt">334</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string" xsi:nil="true"/><Status xsi:type="ns1:CmDevRegStat">Rejected</Status><StatusReason xsi:type="xsd:unsignedInt">6</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">0</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string" xsi:nil="true"/><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1503694558</TimeStamp></item><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEPE0899D944096</Name><IpAddress xsi:type="xsd:string">172.27.178.22</IpAddress><DirNumber xsi:type="xsd:string">60518-Registered</DirNumber><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">435</Model><Product xsi:type="xsd:unsignedInt">334</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string" xsi:nil="true"/><Status xsi:type="ns1:CmDevRegStat">Registered</Status><StatusReason xsi:type="xsd:unsignedInt">0</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">2</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string">Jarod Giel - 60518</Description><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1500648528</TimeStamp></item><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEP5475D005434B</Name><IpAddress xsi:type="xsd:string">172.27.217.76</IpAddress><DirNumber xsi:type="xsd:string">72696-Registered</DirNumber><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">435</Model><Product xsi:type="xsd:unsignedInt">334</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string" xsi:nil="true"/><Status xsi:type="ns1:CmDevRegStat">Registered</Status><StatusReason xsi:type="xsd:unsignedInt">0</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">2</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string">Ann Tully - 72696</Description><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1500648544</TimeStamp></item><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEP002699EF7ED4</Name><IpAddress xsi:type="xsd:string">172.27.164.157</IpAddress><DirNumber xsi:type="xsd:string">68854-Registered</DirNumber><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">435</Model><Product xsi:type="xsd:unsignedInt">334</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string" xsi:nil="true"/><Status xsi:type="ns1:CmDevRegStat">Registered</Status><StatusReason xsi:type="xsd:unsignedInt">0</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">2</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string">Rebecca Navarro - 68854</Description><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1500648009</TimeStamp></item><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEPF02572798B98</Name><IpAddress xsi:type="xsd:string">172.27.185.78</IpAddress><DirNumber xsi:type="xsd:string" xsi:nil="true"/><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">435</Model><Product xsi:type="xsd:unsignedInt">334</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string" xsi:nil="true"/><Status xsi:type="ns1:CmDevRegStat">Rejected</Status><StatusReason xsi:type="xsd:unsignedInt">6</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">0</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string" xsi:nil="true"/><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1503606276</TimeStamp></item><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEPECC882B13567</Name><IpAddress xsi:type="xsd:string">172.27.248.236</IpAddress><DirNumber xsi:type="xsd:string">75392-Registered</DirNumber><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">435</Model><Product xsi:type="xsd:unsignedInt">334</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string">e348157</LoginUserId><Status xsi:type="ns1:CmDevRegStat">Registered</Status><StatusReason xsi:type="xsd:unsignedInt">0</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">2</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string">Colin Hales - 75392</Description><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1502778160</TimeStamp></item><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEP64168D507A9D</Name><IpAddress xsi:type="xsd:string">172.27.160.33</IpAddress><DirNumber xsi:type="xsd:string">60364-Registered</DirNumber><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">435</Model><Product xsi:type="xsd:unsignedInt">334</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string" xsi:nil="true"/><Status xsi:type="ns1:CmDevRegStat">Registered</Status><StatusReason xsi:type="xsd:unsignedInt">0</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">2</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string">Kim Bracey - 60364</Description><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1500648531</TimeStamp></item><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEP64168D50077D</Name><IpAddress xsi:type="xsd:string">172.27.176.81</IpAddress><DirNumber xsi:type="xsd:string" xsi:nil="true"/><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">435</Model><Product xsi:type="xsd:unsignedInt">334</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string" xsi:nil="true"/><Status xsi:type="ns1:CmDevRegStat">Rejected</Status><StatusReason xsi:type="xsd:unsignedInt">6</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">0</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string" xsi:nil="true"/><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1503606270</TimeStamp></item><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEPBCC49396E823</Name><IpAddress xsi:type="xsd:string">172.27.196.254</IpAddress><DirNumber xsi:type="xsd:string">67528-Registered</DirNumber><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">622</Model><Product xsi:type="xsd:unsignedInt">509</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string" xsi:nil="true"/><Status xsi:type="ns1:CmDevRegStat">Registered</Status><StatusReason xsi:type="xsd:unsignedInt">0</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">2</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string">Rachel Muise - 67528</Description><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1500648026</TimeStamp></item><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEPF0257279795E</Name><IpAddress xsi:type="xsd:string">172.27.187.40</IpAddress><DirNumber xsi:type="xsd:string">62024-Registered</DirNumber><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">435</Model><Product xsi:type="xsd:unsignedInt">334</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string" xsi:nil="true"/><Status xsi:type="ns1:CmDevRegStat">Registered</Status><StatusReason xsi:type="xsd:unsignedInt">0</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">2</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string">Joe Murray - 62024</Description><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1500648526</TimeStamp></item><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEPF02572798BF0</Name><IpAddress xsi:type="xsd:string">172.27.205.205</IpAddress><DirNumber xsi:type="xsd:string">69656-Registered</DirNumber><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">435</Model><Product xsi:type="xsd:unsignedInt">334</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string" xsi:nil="true"/><Status xsi:type="ns1:CmDevRegStat">Registered</Status><StatusReason xsi:type="xsd:unsignedInt">0</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">2</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string">Kerry Bajrangi - 69656</Description><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1500648532</TimeStamp></item><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEP002699EF8552</Name><IpAddress xsi:type="xsd:string">172.27.194.71</IpAddress><DirNumber xsi:type="xsd:string">67320-Registered</DirNumber><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">435</Model><Product xsi:type="xsd:unsignedInt">334</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string" xsi:nil="true"/><Status xsi:type="ns1:CmDevRegStat">Registered</Status><StatusReason xsi:type="xsd:unsignedInt">0</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">2</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string">Jomal Whiteside - 67320</Description><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1500648232</TimeStamp></item><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEPF09E630F8322</Name><IpAddress xsi:type="xsd:string">172.27.206.196</IpAddress><DirNumber xsi:type="xsd:string">69430-Registered</DirNumber><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">435</Model><Product xsi:type="xsd:unsignedInt">334</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string" xsi:nil="true"/><Status xsi:type="ns1:CmDevRegStat">Registered</Status><StatusReason xsi:type="xsd:unsignedInt">0</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">2</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string">Matthew Roland - 69430</Description><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1500648532</TimeStamp></item></CmDevices></item><item xsi:type="ns1:CmNode"><ReturnCode xsi:type="ns1:RisReturnCode">Ok</ReturnCode><Name xsi:type="xsd:string">172.27.224.101</Name><NoChange xsi:type="xsd:boolean">false</NoChange><CmDevices soapenc:arrayType="ns1:CmDevice[7]" xsi:type="soapenc:Array"><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEPE05FB92CD61D</Name><IpAddress xsi:type="xsd:string">172.27.157.19</IpAddress><DirNumber xsi:type="xsd:string">45770-Registered</DirNumber><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">435</Model><Product xsi:type="xsd:unsignedInt">334</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string" xsi:nil="true"/><Status xsi:type="ns1:CmDevRegStat">Registered</Status><StatusReason xsi:type="xsd:unsignedInt">0</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">2</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string">K9 Guard Post - 45770</Description><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1503508966</TimeStamp></item><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEPE05FB92CD7AE</Name><IpAddress xsi:type="xsd:string">172.27.226.21</IpAddress><DirNumber xsi:type="xsd:string">31686-Registered</DirNumber><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">435</Model><Product xsi:type="xsd:unsignedInt">334</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string" xsi:nil="true"/><Status xsi:type="ns1:CmDevRegStat">Registered</Status><StatusReason xsi:type="xsd:unsignedInt">0</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">2</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string">Collin Hager - 31686</Description><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1503239560</TimeStamp></item><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEP002699EF0175</Name><IpAddress xsi:type="xsd:string">172.27.154.99</IpAddress><DirNumber xsi:type="xsd:string">44906-Registered,17-Registered</DirNumber><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">436</Model><Product xsi:type="xsd:unsignedInt">335</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string">davenpor</LoginUserId><Status xsi:type="ns1:CmDevRegStat">Registered</Status><StatusReason xsi:type="xsd:unsignedInt">0</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">2</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string">Barry Davenport - 44906</Description><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1502847309</TimeStamp></item><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEP189C5DB79F27</Name><IpAddress xsi:type="xsd:string">172.27.236.27</IpAddress><DirNumber xsi:type="xsd:string">39790-Registered</DirNumber><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">435</Model><Product xsi:type="xsd:unsignedInt">334</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string" xsi:nil="true"/><Status xsi:type="ns1:CmDevRegStat">Registered</Status><StatusReason xsi:type="xsd:unsignedInt">0</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">2</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string">Chris Bolen - 39790 - DCMA</Description><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1499608026</TimeStamp></item><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEPE05FB92CD7D1</Name><IpAddress xsi:type="xsd:string">172.27.226.28</IpAddress><DirNumber xsi:type="xsd:string">39896-Registered</DirNumber><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">435</Model><Product xsi:type="xsd:unsignedInt">334</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string" xsi:nil="true"/><Status xsi:type="ns1:CmDevRegStat">Registered</Status><StatusReason xsi:type="xsd:unsignedInt">0</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">2</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string">RTC Lab - 39896</Description><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1503239691</TimeStamp></item><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEPF02572798B54</Name><IpAddress xsi:type="xsd:string">172.27.228.224</IpAddress><DirNumber xsi:type="xsd:string">32818-Registered</DirNumber><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">435</Model><Product xsi:type="xsd:unsignedInt">334</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string" xsi:nil="true"/><Status xsi:type="ns1:CmDevRegStat">Registered</Status><StatusReason xsi:type="xsd:unsignedInt">0</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">2</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string">Carlos Hernandez - 32818</Description><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1502830463</TimeStamp></item><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEP5CFC665C7334</Name><IpAddress xsi:type="xsd:string">172.27.226.5</IpAddress><DirNumber xsi:type="xsd:string">30424-Registered</DirNumber><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">435</Model><Product xsi:type="xsd:unsignedInt">334</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string">e314946</LoginUserId><Status xsi:type="ns1:CmDevRegStat">Registered</Status><StatusReason xsi:type="xsd:unsignedInt">0</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">2</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string">Mark Adderley - 30424</Description><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1503239409</TimeStamp></item></CmDevices></item><item xsi:type="ns1:CmNode"><ReturnCode xsi:type="ns1:RisReturnCode">Ok</ReturnCode><Name xsi:type="xsd:string">172.27.224.37</Name><NoChange xsi:type="xsd:boolean">false</NoChange><CmDevices soapenc:arrayType="ns1:CmDevice[10]" xsi:type="soapenc:Array"><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEP5CFC665D9637</Name><IpAddress xsi:type="xsd:string">172.27.240.69</IpAddress><DirNumber xsi:type="xsd:string">32771-Registered</DirNumber><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">435</Model><Product xsi:type="xsd:unsignedInt">334</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string" xsi:nil="true"/><Status xsi:type="ns1:CmDevRegStat">Registered</Status><StatusReason xsi:type="xsd:unsignedInt">0</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">2</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string">Matthew Starkey - 32771</Description><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1499607819</TimeStamp></item><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEPF02572799F06</Name><IpAddress xsi:type="xsd:string">172.27.248.134</IpAddress><DirNumber xsi:type="xsd:string">75621-UnRegistered</DirNumber><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">435</Model><Product xsi:type="xsd:unsignedInt">334</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string">e337839</LoginUserId><Status xsi:type="ns1:CmDevRegStat">UnRegistered</Status><StatusReason xsi:type="xsd:unsignedInt">9</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">2</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string">Julian Finlaw - 75621</Description><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1503694562</TimeStamp></item><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEPF02572798B84</Name><IpAddress xsi:type="xsd:string">172.27.232.19</IpAddress><DirNumber xsi:type="xsd:string">31205-Registered</DirNumber><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">435</Model><Product xsi:type="xsd:unsignedInt">334</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string" xsi:nil="true"/><Status xsi:type="ns1:CmDevRegStat">Registered</Status><StatusReason xsi:type="xsd:unsignedInt">0</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">2</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string">James McGinley - 31205</Description><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1496461037</TimeStamp></item><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEPF02572798B98</Name><IpAddress xsi:type="xsd:string">172.27.185.78</IpAddress><DirNumber xsi:type="xsd:string">62777-UnRegistered</DirNumber><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">435</Model><Product xsi:type="xsd:unsignedInt">334</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string" xsi:nil="true"/><Status xsi:type="ns1:CmDevRegStat">UnRegistered</Status><StatusReason xsi:type="xsd:unsignedInt">8</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">2</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string">Jesse Peinado - 62777</Description><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1503606337</TimeStamp></item><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEP002699452D91</Name><IpAddress xsi:type="xsd:string">172.27.157.58</IpAddress><DirNumber xsi:type="xsd:string">45601-Registered</DirNumber><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">435</Model><Product xsi:type="xsd:unsignedInt">334</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string" xsi:nil="true"/><Status xsi:type="ns1:CmDevRegStat">Registered</Status><StatusReason xsi:type="xsd:unsignedInt">0</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">2</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string">H106 Data Cabinet - 45601</Description><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1501693791</TimeStamp></item><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEP64168D50077D</Name><IpAddress xsi:type="xsd:string">172.27.176.81</IpAddress><DirNumber xsi:type="xsd:string">66533-UnRegistered</DirNumber><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">435</Model><Product xsi:type="xsd:unsignedInt">334</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string" xsi:nil="true"/><Status xsi:type="ns1:CmDevRegStat">UnRegistered</Status><StatusReason xsi:type="xsd:unsignedInt">8</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">2</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string">Vince Davila - 66533</Description><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1503607183</TimeStamp></item><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEP189C5DB6E9B4</Name><IpAddress xsi:type="xsd:string">172.28.78.216</IpAddress><DirNumber xsi:type="xsd:string">19845-Registered</DirNumber><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">435</Model><Product xsi:type="xsd:unsignedInt">334</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string" xsi:nil="true"/><Status xsi:type="ns1:CmDevRegStat">Registered</Status><StatusReason xsi:type="xsd:unsignedInt">0</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">2</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string">Office 2nd Floor - 19845</Description><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1502756768</TimeStamp></item><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEP002699F04D53</Name><IpAddress xsi:type="xsd:string">172.27.211.7</IpAddress><DirNumber xsi:type="xsd:string">14043-Registered</DirNumber><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">435</Model><Product xsi:type="xsd:unsignedInt">334</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">1</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string" xsi:nil="true"/><Status xsi:type="ns1:CmDevRegStat">Registered</Status><StatusReason xsi:type="xsd:unsignedInt">0</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">2</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string">Dewar NR Parts Prep - 14043</Description><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1503731418</TimeStamp></item><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEPE05FB92CD743</Name><IpAddress xsi:type="xsd:string">172.27.236.171</IpAddress><DirNumber xsi:type="xsd:string">37017-Registered</DirNumber><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">435</Model><Product xsi:type="xsd:unsignedInt">334</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string" xsi:nil="true"/><Status xsi:type="ns1:CmDevRegStat">Registered</Status><StatusReason xsi:type="xsd:unsignedInt">0</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">2</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string">PC LAB - 37017</Description><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1499901695</TimeStamp></item><item xsi:type="ns1:CmDevice"><Name xsi:type="xsd:string">SEPF02572799ED5</Name><IpAddress xsi:type="xsd:string">172.27.233.32</IpAddress><DirNumber xsi:type="xsd:string">37169-Registered</DirNumber><Class xsi:type="ns1:DeviceClass">Phone</Class><Model xsi:type="xsd:unsignedInt">435</Model><Product xsi:type="xsd:unsignedInt">334</Product><BoxProduct xsi:type="xsd:unsignedInt">0</BoxProduct><Httpd xsi:type="ns1:CmDevHttpd">Yes</Httpd><RegistrationAttempts xsi:type="xsd:unsignedInt">0</RegistrationAttempts><IsCtiControllable xsi:type="xsd:boolean">true</IsCtiControllable><LoginUserId xsi:type="xsd:string" xsi:nil="true"/><Status xsi:type="ns1:CmDevRegStat">Registered</Status><StatusReason xsi:type="xsd:unsignedInt">0</StatusReason><PerfMonObject xsi:type="xsd:unsignedInt">2</PerfMonObject><DChannel xsi:type="xsd:unsignedInt">0</DChannel><Description xsi:type="xsd:string">Dwight Hashaway - 37169</Description><H323Trunk xsi:type="ns1:H323Trunk"><ConfigName xsi:type="xsd:string" xsi:nil="true"/><TechPrefix xsi:type="xsd:string" xsi:nil="true"/><Zone xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer1 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer2 xsi:type="xsd:string" xsi:nil="true"/><RemoteCmServer3 xsi:type="xsd:string" xsi:nil="true"/><AltGkList xsi:type="xsd:string" xsi:nil="true"/><ActiveGk xsi:type="xsd:string" xsi:nil="true"/><CallSignalAddr xsi:type="xsd:string" xsi:nil="true"/><RasAddr xsi:type="xsd:string" xsi:nil="true"/></H323Trunk><TimeStamp xsi:type="xsd:unsignedInt">1496461153</TimeStamp></item></CmDevices></item></CmNodes></SelectCmDeviceResult><StateInfo xsi:type="xsd:string"><StateInfo><Node Name="172.27.192.10" SubsystemStartTime="1450319875" StateId="821" TotalItemsFound="0" TotalItemsReturned="0"/><Node Name="172.27.192.164" SubsystemStartTime="1460587859" StateId="804911" TotalItemsFound="12" TotalItemsReturned="12"/><Node Name="172.27.192.8" SubsystemStartTime="1482361197" StateId="42" TotalItemsFound="0" TotalItemsReturned="0"/><Node Name="172.27.192.9" SubsystemStartTime="1482361153" StateId="464601" TotalItemsFound="16" TotalItemsReturned="16"/><Node Name="172.27.224.101" SubsystemStartTime="1488576716" StateId="386509" TotalItemsFound="7" TotalItemsReturned="7"/><Node Name="172.27.224.37" SubsystemStartTime="1481553464" StateId="320236" TotalItemsFound="10" TotalItemsReturned="10"/></StateInfo></StateInfo></ns1:SelectCmDeviceResponse></soapenv:Body></soapenv:Envelope>
04-20-2020 10:44 AM
Hi Anshu, did you ever find the cause of this?
04-20-2020 04:25 PM
This seems to be some kind of error happening internally to the Risport SOAP service. Would suggest opening a ticket with DevNet Developer Support so we can get some detailed trace logs and identify the root cause: https://developer.cisco.com/site/support/
