Excel application for Cisco call manager.
terry duffy
I created this app in Excel with VBA Microsoft forms and using various Cisco API calls.
It can quickly copy a lot of phones from one model to a different model.
Create new UCCX agents and MACD work, adding or removing a user from a phone.
Quick Youtube video demonstration:
https://youtu.be/xFEIM6Kxv0w
7 Replies 7
Outstanding. I`m needing to do this same type application. Questions if you don`t mind. Is excel doing the api calls to Call Manager?
terry duffy
Yes, Excel is making the API calls. I'm manually creating the AXL SOAP strings and sending them to the CUCM server, then manually parsing the results from the CUCM.
I created a blog that shows how I did some of this: https://ciscocande.wordpress.com/
The blog shows an very early version of the app, before I started using Microsoft forms.
I had started from scratch, learning how to program and learning how to use the CUCM API at the same time.
Great job. I have done some with SoapUI and Postman but having a front end to be able to allow like helpdesk to do the task would be awesome.
rob1456657
Is this tool available for download?
Unfortunately no, I created this specific for our environment, I have considered building a generic one with an enterpriser settings page, so it could be used in other CUCM installations.
Which application function are you mostly interested in? Phone copy?
Yes, that's correct. I have VBA knowledge, is it difficult to change the connection string to the CUCM installation?
The connection string is simple, I have other items hardcoded specifically for our environment, that would need a separate configuration page along with the server IP address for your server.
