UpdateAppUser device to associateddevice
jmn
Level 2
Level 2
Hi all,
I get the following error when trying to Device to appuser associateddevice.
The following error is:
<SOAP-ENV:Envelope SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/">
  <SOAP-ENV:Header />
  <SOAP-ENV:Body>
    <SOAP-ENV:Fault>
      <faultcode>SOAP-ENV:Client</faultcode>
      <faultstring>Element or attribute do not match QName production: QName::=(NCName':')?NCName. </faultstring>
      <detail>
        <axl:Error xmlns:axl="http://www.cisco.com/AXL/API/7.1">
          <axl:code>5001</axl:code>
          <axl:message>Element or attribute do not match QName production: QName::=(NCName':')?NCName. </axl:message>
          <request>updateAppUser</request>
        </axl:Error>
      </detail>
    </SOAP-ENV:Fault>
  </SOAP-ENV:Body>
</SOAP-ENV:Envelope>
My snip of my code is:
        string version = "7.1";
       string soap = "<soapenv:Envelope xmlns:soapenv=\"http://schemas.xmlsoap.org/soap/envelope/\" xmlns:ns=\"http://www.cisco.com/AXL/API/'"+ version +"' \">\n";
        soap += "<soapenv:Header/>\n";
        soap += "<soapenv:Body>\n";
        soap += "<ns:updateAppUser sequence=\"?\">\n";
        soap += "<userid>abxyz/userid>\n";
        soap += "<associatedDevices>    \n";
        soap += "<device>SEP8C705A057CB9</device>\n";
        soap += "</associatedDevices>\n";
        soap += "<ns:/updateAppUserResponse>\n";
        soap += "</soapenv:Body>\n";
        soap += "</soapenv:Envelope>\n";
can some one help me.
Jan Meeling
5 Replies 5
npetrele
You're missing a < here:
Should be...
<userid>abxyz</userid>
Hi Nicholas,
Thanks for your quick response.
I saw it even with the < I get the same error.
Jan
npetrele
Yes, I also noticed you have a mismatched tag.  This:
..should be..
<ns:/updateAppUser>
Here's a working example of the XML request.  I strongly recommend testing out your requests with the free utility SoapUI. You can find and fix problems with your XML that way, and then turn it into code later.
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/10.5">
   <soapenv:Header/>
   <soapenv:Body>
      <ns:updateAppUser sequence="?">
         <userid>daggett</userid>
         <associatedDevices>
            <device>SEP54EE7510D1D0</device>
      </ns:updateAppUser>
   </soapenv:Body>
</soapenv:Envelope>
SoapUI | Functional Testing for SOAP and REST APIs
Hi Nicholas,
Thanks it works fine now, I had made type mismatches.
I have a question.
When the is a device already associated to the Application user and want to add one more how can you do it?
If I do it now it removed the device that already there.
Jan Meeling
dstaudt
In the case of associated devices, you would need to perform a <getUser> request first to retrieve the current list of associated devices, make you modifications and then use <updateUser> to submit the replacement list.
Note, it is also possibly to do this more a bit more efficiently (though with other caveats like backward compatibility and complexity) by using direct SQL commands via <executeSqlQuery>/<executeSqlUpdate> - see the Data Dictionary for CUCM table/field details.  You would mainly be interested in the 'enduser', 'device' and 'enduserdevicemap' tables.
