Desktop PCs Functiona
Alex09st
Community Member
What I want to do is 2FA the RD Gateway – so anyone using the gateway from the internet has to use 2FA. I don’t want to make the branch users using the RemoteApp version of Act from ACT01 to have to 2FA – they’re already on machines in the physical stores that are on the VPN, and presumably OK – if not I have bigger problems. But I want anyone coming into the RD Gateway from the internet have to 2FA to get an RD session, either to RemoteApp to ACT01 to run Act, to get a desktop session to use it as a jump host, or to connect to their desktop PCs.
BabbittJE
Level 3
Level 3
Install Duo for Remote Desktop Gateway. That’s how mine is set up. External Users coming in from the RDG are prompted by Duo for 2FA. Internal users are not prompted.
