Duo with Radius and Local ASA users
Phil Bradley
Level 4
Level 4
Is it possible to setup both Radius and local users using DUO with a Cisco ASA? Currently I have the proxy setup and I am using DUO with my AD users with the ASA. However, I have contractors that do not have AD credentials that I would like to use 2 factor with as well.
Phil Bradley
Level 4
Level 4
I see in the documentation that you can specify the ports for each application in the config. I think I can accomplish this by using a different port for the local users. I am going to give this a try and see what happens.
