10G license installation on ME 3600X
Krasnov343
Hello colleagues,
Could you please help me with one small question. I'm installing 10G license on ME-3600X-24FS-M. This is what I've got before installation:
Switch# sh license
Index 3 Feature: 10GEUpgrade
        Period left: 8  weeks 4  days
        License Type: Evaluation
        License State: Active, Not in Use, EULA not accepted
        License Count: Non-Counted
        License Priority: None
Switch#
After the license was installed:
Switch#sh license
        Period left: Life time
        License Type: Permanent
        License Priority: Medium
Switch#
My question is - why license state is Not in Use. There is no sfp+ installed in the switch. Could this be the reason?
Kind regards,
Oleg Krasnov
7 Replies 7
sg2
Hi Oleg,
   you would need to change the SDM template for this... (sdm prefer 4 or 3 )...by default the I/O mode is 1 and thus, you will be seeing the 10GEupgrade feature as "Not in Use".
refer link for detailed explanation:
http://www.cisco.com/en/US/docs/switches/metro/me3600x_3800x/software/release/15.3_1_S/configuration/guide/swsdm.html#wp1102780
Also, refer to below link for details on license types on ME3600X:
http://www.cisco.com/en/US/prod/collateral/switches/ps6568/ps10956/data_sheet_c78-601946.html
you can check your devices current I/O mode by giving "show sdm prefer" cmd.
hope this answers ur query.
Hi Suma,
Thanks for your help!
Changing of SDM template covers ME 3600-24CX configuration and this configuration is not valid for ME 3600-24FS-M, that I use.
There is no such options in ME-3600-24FS-M:
Switch#sh sdm prefer ?
  current  show current template configuration
  default  show default template configuration
  ip       show ip template configuration
Switch#
BR,
Oleg
The problem is this:
The output is quite misleading on the 3600’s              .
It’s says evaluation and not in use.
Index: 2        Feature: 10GEUpgrade                       Version: 1.0
        License State: Inactive
            Evaluation total period: 8  weeks 4  days
            Evaluation period left: 8  weeks 4  days
            Period used: 0  minute  0  second
        Store Index: 1
        Store Name: Built-In License Storage
Plug in a 10Gig interface:
        License State: Active, In Use
hi!
i have same a problem. but if  use I/O Mode 2 or Mode 3 i cant enable mpls functions on tengig ports. can you tell me, what i need to do for usage 4 tengig ports and usage in this port mpls functions
Plugging in the SFP module will trigger the license and you will be able to use it afterwards.
larunkum
Hi Oleg ,
Could you please help me to upgraded/install the switch license for 10GE.
I am facing issue with Switch "ME-3600X-24TS-M" as 10GE license has expired.
Switch#show license
Period left: 0 minute 0 second
Period Used: 8 weeks 4 days
License State: Active, Not in Use, EULA accepted
License Priority: Low
Lovely.
Most likely you need to buy a new 10G licence and activate it on the switch.
