3750me - eompls and stp
barbara.costantini
Community Member
In the lab I have six routers connected as described below
[CE-3550-12T]-[PE1-3750me]--[P1-6500sup720]--[P2-3750me]--[PE2-3750me]-[CE-3550-12G]
I've enabled mpls on the PE e P routers and I've configurated an Eompls tunnel between two PE routers.(vc id 300)
I've connected on the fast 1/0/5 in both PEs two catalyst 3550 as CE routers.
I'd like to carry transparently the CE's vlans (16,17) on the backbone mpls so I've configurated the fast 1/0/5 in both PE in mode dot1q tunnel and in access vlan 300.
interface FastEthernet1/0/5
description EOMPLS PE1
switchport access vlan 300
switchport mode dot1q-tunnel
switchport protected
load-interval 30
mdix auto
l2protocol-tunnel shutdown-threshold cdp 600
l2protocol-tunnel shutdown-threshold stp 600
l2protocol-tunnel shutdown-threshold vtp 600
l2protocol-tunnel drop-threshold cdp 400
l2protocol-tunnel drop-threshold stp 400
l2protocol-tunnel drop-threshold vtp 400
l2protocol-tunnel cdp
l2protocol-tunnel stp
l2protocol-tunnel vtp
no cdp enable
spanning-tree bpdufilter enable
end
interface Vlan300
no ip address
mpls l2transport route 172.9.9.9 300 vc-type vlan
tag-switching ip
end
The spanning-tree of vlan 300 is disabled whereas stp is enabled for the ce's vlans (16 17).
The eompls tunnel goes up and I've IP connectivity between CE routers.
PE2#sh mpls l2transport vc 300 detail
vcid: 300, type: vlan , local groupid: 63, remote groupid: 58 (vc is up)
client: Vl300 is up, destination: 172.9.9.9, Peer LDP Ident: 172.9.9.9:0
local label: 24, remote label: 96, tunnel label: 22
outgoing interface: Vl3002, next hop: 172.19.9.17
Local MTU: 1504, Remote MTU: 1504
Remote interface description: Vlan300
Packet totals(in/out): 1312/1313
byte totals(in/out): 143440/148796
But I note that both CE routers are root bridge for vlan 16,17 and on both PE routers the counters of stp encapsulated packets increase whereas the counters of stp de-capsulated packets are zero.
PE2#SH L2protocol-tunnel INterface FAST 1/0/5
COS for Encapsulated Packets: 5
Port Protocol Shutdown Drop Encapsulation Decapsulation Drop
Threshold Threshold Counter Counter Counter
Fa1/0/5 cdp 600 400 0 0 0
stp 600 400 3 0 0
vtp 600 400 0 0 0
Is my configuration incorrect?
Why doesn't the eompls tunnel carry across the backbone the stp packets?
Must I set the "vlan dot1q tag native" on the PE and CE routers?
Thanks in advance
B.
7 Replies 7
romccallum
Level 8
Level 8
two things - try disabling spanning tree for vlan 300 on the 3750. Also try to change the vc-type to ethernet instead of vlan.
Thanks for the help
I've tried but the result is the same.
I think that the problem is this bug
CSCee30284
The EoMPLS tunneled ports (both port-based and VLAN-based) on a switch do not tunnel Layer 2 protocol packets that are received from the customer switch to the remote (egress) provider edge switch. The Layer 2 protocols packets are either consumed by the switch or, if Layer 2 protocol tunneling is enabled, are passed along by the standard Layer 2 protocol tunneling mechanism (outside the EoMPLS tunnels).
There is no workaround.
Thanks for all
B.
You are correct. I have run into the same issue. Suggested solution was to place 3550s in front of the 3750 to do your l2tunnel.
In my case, it was CDP. This option may or may not work for you.
as far as I know there's no stp forwarding in eompls circuits.
I have no idea if they have added this functionality in any other IOS version.
lookup l2protocol tunnel mate - you can do vtp, stp and cdp.
kayjoon
Community Member
ok
istein001
Community Member
I know this is old... but :
spanning-tree bpdufilter enable -> filters all STP BPDU's... so they don't even get encasulated and passed on.
We use this when customers have configured their STP or Trunk ports incorreclty and are gettting error disabled ports, when we know they have a loop free topology.
