ASR920 EVPLAN Configuration
nwilson.network
I'm new to carrier class ethernet, but I'm trying to understand what I'm needing to do. I don't know if I'm looking at the wrong solutions, or just misunderstanding the implementation.
I have an ASR920. We will be slowly moving everything to carrier class over the next 5 or so years. Right now I have a trunk port on a pair of 6504s I'd like to connect as the uplink to the ASR920.
I need to accept all VLANs from the 6504s, but I need to spit some of those VLANs out on the 920 gig ports as untagged access ports. I also need to carry some of those VLANS out other ports. Is EVPLAN the right solution? Or should I be looking elsewhere? We have an adtran environment, but that config for doing something like this is incredibly easy. So I feel like I'm just misunderstanding the change in verbage.
For a while today I was exploring configuring each of those ports as C-UNI, but that didn't seem to work.
Is there any good Cisco books for learning carrier class configuration?
rehernandez
Hi Wilson,
Maybe this solution could help you.
https://community.cisco.com/t5/switching/asr920-vlan-tagging/m-p/3854220
