Bandwidth restriction on FastEthernet interface
tvm_parthiban83
Community Member
5 Replies 5
spremkumar
Level 11
Level 11
hi
You can make use of CAR (Rate-limit) commands to restrict the bandwidth as per the requirement.
Also you can make use of Class based policing to achieve the same.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800c75ce.html
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00804a27c4.html
regds
thanks for your info.
i tried but i dont have enough privilege level to craete policy in switch
so without policy how can i implement CAR in interface.
and i need a one more info if more than one customer connected on that interface ech having separate vlan id.
so can i implement this car in vlan interface?
hi
I did give the CAR suggestion thinking off that you are trying with your router.
Pls post out the switch model and info on how the customers are getting connected to the switches..
regds
hi
regds
hi
regds
