Channel Freezing in specific VLANs
sajism220
Hi ,
This is regarding IPTV channel freezing issue which I am facing these days,
We have some 100 no's of vlan in one of our PE for IPTV, out of that from one of the VLAN which is conencting to one access switch, users are facing issue with channel freezing..I had extended another vlan and its work fine..
When  this issue happend the resident normally needs to channel up and channel down to unfreeze a certain channel.
Cisco IOS Software, C3750ME Software (C3750ME-I5K91-M), Version 12.2(44)SE2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 01-May-08 16:45 by antonino
Image text-base: 0x00003000, data-base: 0x01C1A800
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750ME Boot Loader (C3750ME-HBOOT-M) Version 12.1(14r)AX, RELEASE SOFTWARE (fc1)
pa7-th-gf-idf1-a1 uptime is 1 week, 4 days, 6 hours, 54 minutes
System restarted at 11:08:44 GMT Tue Feb 22 2011
System image file is "flash:/c3750me-i5k91-mz.122-44.SE2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html you require further assistance please contact us by sending email to
export@cisco.com. ME-C3750-24TE (PowerPC405) processor (revision H0) with 0K/12280K bytes of memory.
Processor board ID FDO1322Z0DU
Last reset from power-on
2 Virtual Ethernet interfaces
24 FastEthernet interfaces
4 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
If
cisco
1024K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:25:B4:8A:04:00
Motherboard assembly number     : 73-9938-05
Motherboard serial number       : FDO132103DE
Model revision number           : H0
Motherboard revision number     : B0
Model number                    : ME-C3750-24TE-M
Daughterboard assembly number   : 73-11675-02
Daughterboard serial number     : FDO13210386
System serial number            : FDO1322Z0DU
Top Assembly Part Number        : 800-25952-06
Top Assembly Revision Number    : A0
Version ID                      : V07
CLEI Code Number                : COMS900ARA
Daughterboard revision number   : A0
Hardware Board Revision Number  : 0x09
Switch Ports Model              SW Version            SW Image
*    1 28    ME-C3750-24TE      12.2(44)SE2           C3750ME-I5K91-M
Configuration register is 0xF
Vlan 436:   //  Thisi is the probelm vlan
IGMP snooping                       : Enabled
IGMPv2 immediate leave              : Disabled
Multicast router learning mode      : pim-dvmrp
CGMP interoperability mode          : IGMP_ONLY
Robustness variable                 : 2
Last member query count             : 2
Last member query interval          : 100
Vlan 437:
Vlan 438:
can you reply with suggestions
sajism220
not working vlan:
pantr1-d1#sh ip igmp groups vlan 436
IGMP Connected Group Membership
Group Address    Interface                Uptime    Expires   Last Reporter   Group Accounted
239.232.1.26     Vlan436                  02:05:25  stopped   10.96.82.249
239.232.2.104    Vlan436                  00:04:10  stopped   10.96.82.226
239.232.2.108    Vlan436                  00:04:09  stopped   10.96.82.232
239.232.4.24     Vlan436                  00:04:10  stopped   10.96.82.239
239.232.8.2      Vlan436                  00:04:08  stopped   10.96.82.234
239.232.8.8      Vlan436                  00:06:30  stopped   10.96.82.248
239.232.123.11   Vlan436                  02:06:13  stopped   10.96.82.235
working vlan:
pantr1-d1#sh ip igmp groups vlan 438
239.232.1.26     Vlan438                  2d09h     stopped   10.96.83.153
239.232.2.96     Vlan438                  00:05:23  stopped   10.96.83.152
239.232.2.108    Vlan438                  06:44:29  stopped   10.96.83.158
239.232.123.11   Vlan438                  2d09h     stopped   10.96.83.152
traceroute from dc4 to pantr1-d1 vlan 436 reciver IP
bdc-dc4#mtrace 10.96.82.247 239.232.8.9 192.168.120.0
Mtrace from 10.96.82.247 to 172.16.11.22 via group 239.232.8.9
From source (?) to destination (?)
Querying full reverse path... * switching to hop-by-hop:
0  172.16.11.22
-1  172.16.11.22 PIM  [10.96.64.0/18]
-2  172.16.11.21 None  [10.96.64.0/18]
-3  172.16.11.42 None  [10.96.64.0/18]
-4  * * * 172.16.1.130                        // it is not reaching destination, is it normal ???
traceroute from dc4 to pantr1-d1 vlan 438 reciver IP
bdc-dc4#mtrace 10.96.83.152 239.232.8.9 192.168.120.0
Mtrace from 10.96.83.152 to 172.16.11.22 via group 239.232.8.9
0  172.16.11.22
-3  172.16.11.50 None  [10.96.64.0/18]
-4  172.16.2.130 PIM  [10.96.83.128/25]
-5  10.96.83.152
