Bridge Domain and multicast traffic
aviyoshi10
Hi All,
i am planning to build a Point to multipoint network based on ME3600X switch at the HQ and ISR 2900 routers at the Branches. i need to simulate a lan service.
i though of using EOMPLS at the ISR 2900 and closing them at the ME3600X. at the ME3600X i will use bridge domain to have this point to multipoint functionality.
at the configuration guide i saw that when i am using bridge domain i need to disable IGMP snooping on every Vlan.
my question is how the bridge domain treat Multicast traffic ?
furthermore, can i mix EOMPLS and Bridge Domain ?
Avi.
Laurent Aubert
Hi Avi,
ME3600X doesn't support VPLS yet (check with your account team for the roadmap) so I don't think your design will work here. What you can do is having a router behind the ME3600X which will have a dedicated VLAN with each remote site.
Laurent.
