Differentiating between 802.1q and 802.1ad frames
ajsouthard
Does anyone know how to set up a qos policy that can classify based on whether an incoming frame is 802.1q (single tagged) or 802.1ad (double tagged) on an ME3400E?
Bastien Migette
Thanks a lot for your suggestion.
I have played around with this feature and unfortunately it looks like the ingress interface has to be configured as a dot1q tunnel in order for the match inner vlan option to work. We want the interface to be a plain 802.1q trunk interface. Also, to use this feature we would have to know the vlan numbers and match on each one. In our environment the interface will be a UNI to a customer so we will not know (or want to know) the inner vlans being used.
