Disabled txpower on some ports when fully populating WSC4506E with WS-X4640-CSFP-E on bootup
Philip Olsson
We have a issue where some CSFP's, every third or so, have disabled txpower on bootup (-40dBm in show int tran ) if you populate a 4506E chassis with 4 or more WS-X4640-CSFP-E. "hw-module module 2 reset" brings up the card in functioning state.
Swapping the LC's does not help, tested on several boxes and with different types of power supplies.
The ports can be completely unconfigured and it still happens. Every port have the same configuration.
Completely new hardware. Tested two IOS:
14755  -rw-   126060564   Aug 7 2014 13:42:10 +02:00  cat4500e-universalk9.SPA.03.04.04.SG.151-2.SG4.bin
14756  -rw-   177993372   Sep 5 2014 05:11:57 +02:00  cat4500e-universalk9.SPA.03.06.00.E.152-2.E.bin
Is anyone using fully populated C4506E / SUP7LE / WS-X4640-CSFP-E with success?
See below for some output of commands.
Philip
sh int gi2/59
GigabitEthernet2/59 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet Port, address is f40f.1ba7.2d0a (bia f40f.1ba7.2d0a)
  Description: FTTH
  MTU 1552 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, Auto-speed, link type is auto, media type is 1000Base-2BX10-D
  input flow-control is off, output flow-control is off
  Last input never, output never, output hang never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 5 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier
show int tran
Gi2/1        36.1       3.24      -6.1     -40.0
Gi2/2        36.1       3.24      -6.6     -40.0
Gi2/3        32.7       3.25     -40.0     -40.0
Gi2/4        32.9       3.25      -6.7     -40.0
Gi2/5        37.8       3.24      -5.9     -40.0
Gi2/6        38.0       3.24      -6.9     -40.0
Gi2/7        34.7       3.26     -40.0     -40.0
Gi2/8        34.7       3.26      -6.0     -40.0
Gi2/9        36.1       3.24      -5.3     -40.0
Gi2/10       36.1       3.24      -5.9     -40.0
Gi2/11       34.7       3.26     -40.0     -40.0
Gi2/12       34.7       3.26      -5.5     -40.0
Gi2/13       36.9       3.23      -5.6     -40.0
Gi2/14       36.9       3.23      -5.9     -40.0
Gi2/15       35.2       3.25     -40.0     -40.0
Gi2/16       35.0       3.25      -5.5     -40.0
Gi2/17       34.7       3.21      -6.7     -40.0
Gi2/18       34.7       3.22      -5.7     -40.0
Gi2/19       36.6       3.26     -40.0     -40.0
Gi2/20       36.7       3.25      -6.5     -40.0
Gi2/21       34.6       3.24      -5.9     -40.0
Gi2/22       34.6       3.24      -6.3     -40.0
Gi2/23       35.6       3.26     -40.0     -40.0
Gi2/24       35.6       3.25      -6.1     -40.0
Gi2/25       37.4       3.22      -5.6     -40.0
Gi2/26       37.4       3.22      -6.8     -40.0
Gi2/27       37.1       3.26     -40.0     -40.0
6 Replies 6
Roger Saugestad
Have you found a solution to this?  I see the same isssue on WS-C4503-E chassis and WS-X45-SUP8-E supervisor and WS-X4640-CSFP-E linecards.
When we move the linecards to a Sup6 device everything works as normal so I don's suspect there is something wrong with the hardware.
Do you have problems with negotiating speed on the working Gig interfaces as well? I need to set 'speed nonegotiate' on the interfaces to get link, but 'sh int transceiver' shows both optical RX og TX signal.
Roger
Hi Roger,
We are currently waiting for Cisco TAC to verify this issue, they are waiting for hardware for their labs. Maybe in the beginning of December there is acknowledgement from Cisco on the issue...
I have confirmation from another service provider that they are having the same issues, they have also a TAC case going on, but afaik, without progress.
I can confirm that these cards/SFP's seems to have a issue when running "speed nonegotiate", it seems to link up with itself. Quite random. I have not followed up this issue.
EDIT: The self linkup happens when there is no cable connected, I suspect there is not enough isolation in the SFP between tx laser and rx sensor.
// Philip
We are seeing the same thin on our 4506E chassies with SUP7E and the 4640 linecards.
The problem always appears on port 3 and then on every 4th port as seen in the post above.
We've had some succes resolving this by either toggling the adminstate of the ports or by resetting the whole linecard. At the moment though we are in a situation where these tricks doesn't help at all.
I've opened a TAC-case on the issue but with no feedback yet.
Has anyone got any explanation from Cisco regarding this behavior?
Daniel
We are still waiting for Cisco to get their lab togheter.
But maybe you can do the following if you have a lab enviroment available.
switch(config)#service internal
switch(config)#end
switch#debug platform logging feature glmpluggable
switch#debug platform logging feature linecardinterrupts
switch#debug platform logging feature transceiver
We would have to reboot the device and as soon as supervisor comes up we should enabled debugs (line cards are still booting) and stop debugs once some of the ports go down. At that time it would be helpful to gather "show int tran" to see which ports are impacted.
Additionally I would suggest to increase logging buffer size to capture all debugs and disable logging debug output to both console and monitor.
Can you please advise if you can proceed with above steps?"
Philip Olsson
Hey Guys,
Cisco have finally reproduced the issue in their lab, so keep an eye on issue: CSCur84243
There is no fixed software available yet.
/ Philip
This is good news, now we are able to track status on this bug.
Roger
