Dot1Q tunneling QOS on ME3400
lvanacker
Is it possible on a ME3400 to copy or rewrite customer Cos into Service provider Cos on Dot1q tunneling port ?
thanks
Luc
lorenagarcia
I have configured the next class-map and policy-maps but I only can apply the service-policy in trunk ports. How Can I configure a service-policy in a access-port?
Class Map match-all COS7
Match cos 7
Class Map match-all COS6
Match cos 6
Class Map match-all COS5
Match cos 5
Class Map match-all COS4
Match cos 4
Class Map match-all COS3
Match cos 3
Class Map match-all COS2
Match cos 2
Class Map match-all COS1
Match cos 1
Class Map match-all COS0
Match cos 0
Class Map match-any VLAN
Match vlan 1-4094
policy-map MARCADO_ENTRADA
Class VLAN
service-policy MARCADO
Class class-default
policy-map MARCADO
Class COS1
set dscp 15
Class COS0
set dscp af11
set cos 4
Class COS2
set dscp af22
Class COS3
set dscp 25
Class COS4
set dscp af33
Class COS5
set dscp 35
Class COS6
set dscp cs5
Class COS7
set dscp 45
interface FastEthernet0/1
description # Conex ANILLO con 3400_1
port-type nni
switchport mode trunk
logging event spanning-tree
logging event status
storm-control broadcast level 0.50
storm-control multicast level 0.50
storm-control action trap
no cdp enable
service-policy input MARCADO_ENTRADA
ip dhcp snooping trust
end
When I apply the service-policy input in the fa0/1 and I send traffic I can't see any COS traffic.
Could you help me to configure this??
Why I can see traffic in the interface?
SW_3400_2#sh policy-map interface fa0/1
FastEthernet0/1
Service-policy input: MARCADO_ENTRADA
Class-map: VLAN (match-any)
0 packets
Match: vlan 1-4094
Service-policy : MARCADO
Class-map: COS1 (match-all)
0 packets
Match: cos 1
Set dscp 15
Class-map: COS0 (match-all)
0 packets
Match: cos 0
Set dscp af11
Set cos 4
Class-map: COS2 (match-all)
0 packets
Match: cos 2
Set dscp af22
Class-map: COS3 (match-all)
0 packets
Match: cos 3
Set dscp 25
Class-map: COS4 (match-all)
0 packets
Match: cos 4
Set dscp af33
Class-map: COS5 (match-all)
0 packets
Match: cos 5
Set dscp 35
Class-map: COS6 (match-all)
0 packets
Match: cos 6
Set dscp cs5
Class-map: COS7 (match-all)
0 packets
Match: cos 7
Set dscp 45
Class-map: class-default (match-any)
0 packets, 0 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: any
0 packets, 0 bytes
Match: any
SW_3400_2#
