ES20 and ES+ Port Aggregation
huydien3384
Hi pro,
Could these ports on ES20 and ES+ bundled together?
Giuseppe Larosa
Hello Huydien,
yes
see
http://www.cisco.com/en/US/docs/routers/7600/install_config/ES20_config_guide/baldovw.html#wp1075778
Layer 2 Features
Layer 2 switch port  (EtherChannel only)
EtherChannel and Link Aggregate  Control Protocol (IEEE 802.3ad)
An EtherChannel bundles individual Ethernet links  into a single logical link that provides the aggregate bandwidth of up  to eight physical links.The EVC EtherChannel feature provides support  for EtherChannels on Ethernet Virtual Connection Services (EVCS) service  instances.
http://www.cisco.com/en/US/docs/routers/7600/install_config/ES40_config_guide/es40_chap4.html#wp1460596
comment:
these are ports with a lot of features so if you need a simple L2 etherchannel it would be better to use 2 ports of a simple GE linecard
Hope to help
Giuseppe
Hi Giuseppe,
When I configured port-channel btw two port on different linecards, the router notified that cannot do that because qos-type of these line cards are not the same. I issued "no mls qos channel-consistency", but did not know how this impact the network performance.
Under default configuration ports in ES20, we have "mls qos trust", but not in ES+, so what is the alternative command for "trust qos" on ES+?
Thanks!
Hello Huydien,
ES+ looks like to support modular QoS marking instead of port trust see
http://www.cisco.com/en/US/docs/routers/7600/install_config/ES40_config_guide/es40_chap7.html#wp1374723
given this I'm afraid the QoS capabilities mismatch is real, you could implement a policy map to mark all incoming traffic but how to apply it only to a member of the bundle?
Hope to help
Giuseppe
