I'd like to be able to configure an inward (UP) facing MEP on the ES+ interface as I have directly attached (unmanaged) CPE.
Is this possible in 12.2(33)SRE1?
When i try and apply a MEP to the physical interface or service instance I see the following message.
router(config-if)# ethernet cfm mep domain CUSTOMER mpid 1 vlan 7
Up direction MEP is not supported on Gi7/19. Command Aborted.
