06-02-2010 03:14 PM
I am having a heck of a time trying to configure rate-limiting on the 3400me switch for outgoing traffic. I basically have two ports that are facing the switch from a subscriber network and one on the service provider network.
port 1 -> subscriber
port 2 -> subscriber
port 4-> provider
There port 1,2 will be configured with a /30 ip address and a vlan will be passed in through port 4 from the provider network which is also a /30.
policer aggregate NWMNSA_DOWN cir 5120000 bc 960000 conform-action transmit exceed-action drop
class-map match-all WELLY
match qos-group 5
policy-map NWMNSPA_DN
class class-default
police aggregate NWMNSA_DOWN
policy-map TEMP
class WELLY
shape average 5000000
policy-map MARKIT
class class-default
set qos-group 5
interface GigabitEthernet0/1
description Video
no switchport
ip address 10.10.10.245 255.255.255.252
load-interval 30
service-policy input MARKIT
interface GigabitEthernet0/2
description Video
no switchport
ip address 10.10.10.249 255.255.255.252
load-interval 30
interface GigabitEthernet0/4
port-type nni
switchport trunk allowed vlan 555
switchport mode trunk
service-policy input NWMNSPA_DN
service-policy output TEMP
interface Vlan555
ip address 10.10.10.242 255.255.255.252
My Download or input policy takes action like I would expect. I have tried a ton of configuration choices to try and resolve this. The problems is I want to share 5Mb between g0/1 and g0/2 and not put input policies on them or rate limit at that point. On other vendors switches this is so simple. I can get this to work when i just use the interface as a uni in a similar manner, but the qos-groups must strip when they get routed through the switch. Basically I am trying to get 5Mb input and 5mb output when i use the switch. I do not want the total of 5Mb for upstream to be passed up my network and prefer to use the g0/4 to rate-limit the outgoing connection as a group if i can. I had it working earlier, but the qos-group function didn't apparently matter so I think I hit a bug.
Solved! Go to Solution.
06-07-2010 09:34 AM
Hello Jwilde,
thanks for your feedback it makes this a complete story
Best Regards
Giuseppe
06-04-2010 08:50 PM
I think i found a bug i backgraded and it works as i would expect.
06-06-2010 11:11 AM
Hello Jwilde,
for making this case complete may you add what was the initial IOS image running on the device and with what image you have fixed your problem?
Have you done a bug search if so you are allowed to mention the Cisco bug id affecting your system
Hope to help
Giuseppe
06-06-2010 11:52 AM
The version I got it working as expected on is: Version 12.2(44)EY. The version that I had issues with was me340x-metroipaccessk9-tar.122-54.SE and -53. I have not looked through the bug reports on the issue but I may do that later. I thought I was doing something wrong all along.
06-06-2010 04:41 PM
I did not find anything under the bugs.
06-07-2010 09:34 AM
Hello Jwilde,
Best Regards
Giuseppe
