How can I measure my maximum throughput from the leased line that I got from ISP?
George-Sl
I don't know if this is the right forum.
So I work for a Service Provider, and we got 2 new internet leased lines over fiber(LACP), 2x10 Gb from another department(same entity) not so far from us, I Port-Channeled those two to my Cisco Firepower, and tested the internet throughput with speedtest.net, which I don't think is the best way, but I don't know any other way to measure, how should I measure?
remember the link itself is 20Gb but how much internet data I can flow over it, is different, it supposed to be the same, but it wasn't according to speedtest.net, I ran a concurrent test with 3 laptops(gb network adapeter) at the same time, and it wasn't.
What do you suggest?
Elvin Arias
Have you checked RFC 2544 and related?
Elvin
gachilleas
You can try with jperf tool but you should host the server in public server.
