Interface serial issues 900
jspsumit8880
Frequent Visitor
Frequent Visitor
Interface serial option not showing asr 900 instead of showing serial acr and serial pg
balaji.bandi
Can you post information here - show version  and what you defined as issue output
or refer below configuration guide ;
https://www.cisco.com/c/en/us/td/docs/routers/asr903/software/guide/chassis/xe-3s/b_Config_Guide_fullbook/b-cfg-serial-int.html
BB
router version ios xe 17.03.04
I have a900-ima48d-c card on asr router
card type e1 0 3
controller e1 0/3/17
int cem 0/3/17
ip commond showing
error ip configuration not allowed on cem interface
and interface serial command not showing on router
The module you referring was  T1/E1 Module :
Cisco ASR 900 Series 48-Port T1/E1 Module (A900-IMA48D-C)
not that i am aware you can configure IP- check below guide :
https://www.cisco.com/c/en/us/td/docs/wireless/asr_900/hardware/installation/b-asr903u-hig.pdf
BB
