Dear Master,
I'm deploying a new Metro Ethernet network and I'm not sure which OAM protocol fault Management should be use “802.1 g (CFM) or the new Y1731 FM”. All examples that I am seeing are using 802.1ag for Faults and Y1731 for Performance. Now the Y1731 covers the AM and FM.
My doubt:
If I choose to use only the Y1731 for FM and PM I will facing problem with interoperability with another Server Provider that use 802.1 ag "CFM"? Below you can see the drawing representing the doubt.
Thanks in advance for any help.
Adriano Filgueiras
