limit bandwidth
d-mark
Level 4
Level 4
I'm running a MetroEthernet witch 3750 as backbone switces and 2950/3560 at the
edges which is configured as switched layer 2 network. Throuout this network I want to provide different VLANs with different bandwidths. To find a working configuration I've setup a small test scenario, consiting of two 3560, one as the 'layer2 network' and the ohter one as layer3 device with VLAN-interfaces and ip routing enabled.
What I want to achieve is that the traffic on VLAN 150 (interface FastEthernet0/15, ip net 192.168.150.0/24) is limited to 1MBit/s and the traffic on VLAN 160 (interface FastEthernet0/16, ip net 192.168.160/24) is limited to 2MBit/s. I've read the 'Configuring QoS' chapter of 'Catalyst 3560 Switch Software Configuration Guide' and tried the config attached below, but it's not working.
Maybe someone of you could give me a hint, about what I'm doing wrong?
thanks in advance
Mark
version 12.2
no service pad
service timestamps debug datetime localtime show-timezone
service timestamps log datetime localtime show-timezone
hostname ts2
enable secret 0 xxx
no aaa new-model
vtp mode transparent
ip subnet-zero
no ip domain-lookup
ip tftp source-interface Vlan121
mls qos
no file verify auto
mac access-list extended everythingL2
permit any any
spanning-tree mode mst
no spanning-tree optimize bpdu transmission
spanning-tree mst configuration
name main-mst-region
revision 1
instance 1 vlan 1-4094
spanning-tree mst forward-time 7
spanning-tree mst max-age 15
vlan internal allocation policy ascending
vlan dot1q tag native
vlan 111,121,130,140,150,160
class-map match-all EveryMAC
match access-group name erverythingL2
class-map match-all V160
match access-group 16
class-map match-all V150
match access-group 15
policy-map InetUp
class V150
police 1000000 100000 exceed-action drop
class V160
police 2000000 200000 exceed-action drop
policy-map 1MBits
class EveryMAC
policy-map 2MBits
class EveryMAC
interface FastEthernet0/4
switchport trunk native vlan 111
switchport mode trunk
service-policy input InetUp
description internet access -> ts2 vlan150
switchport access vlan 150
switchport mode access
service-policy input 1MBits
spanning-tree bpdufilter enable
spanning-tree guard root
description internet access -> ts2 vlan160
switchport access vlan 160
service-policy input 2MBits
interface Vlan121
description management
ip address 10.66.153.76 255.255.255.0
ip default-gateway 10.66.153.1
ip classless
no ip http server
access-list 15 permit 192.168.150.0 0.0.0.255
access-list 16 permit 192.168.160.0 0.0.0.255
line con 0
line vty 0 4
password xxx
login
end
11 Replies 11
mheusinger
Level 11
Level 11
do you get matches in your ACLs?
You are applying a policy matching on IP addresses on a L2/trunk port.
Can you try to match on input interface or VLAN?
Regards, Martin
Hi Martin,
thanks for your reply. A "show access-list [15|16]" don't show any matches. The output of a "sh policy-map interface fa0/[15|16]" also shows nothing, that would look like the policy-map ist working.
If tried to match/classify on the different VLANs, but couldn't find a way how this can be done.
Classification/Matching on the input interface may be possible in this test scenario. But in the real network the input interfaces (Fast0/15 & fast0/16) are distributed on different devices throughout the network.
thanks and kind regards
Mark
Mark,
can you explain "But in the real network the input interfaces (Fast0/15 & fast0/16) are distributed on different devices throughout the network."
The QoS you apply is a "rule set" local to the switch. Traffic outside the switch can not be handled. I seem to misunderstand something here.
Where should the limit be applied, where does the traffic come from? Can you be more specific about the topology and the goal you would like to achieve?
Thank you.
Regards, Martin
the 'real' network is a layer 2 transport network, consisting of a backbone build by 3750 and 2950/3560 at the edges. What I want to achieve is provide access to the internet from different places with different bandwidths. Here the different places are access ports at the edge switches (like fa0/15 in the example/test config above) and the connetion to the internet is a trunk port (like fa0/4 in the example/test config above). This trunk port leads to another switch, who's in routing mode an has different vlan-interfaces for the different places.
Because, as far as I know, policing could be done only at the 'input direction' of a physical interface (eg. FastEthernet), my approch is to limit the input bandwidth at both ends of a connetion.
Mark
Hm,
you might want to try this idea. Mark any traffic destined to internet with cos 1 and use the cos value to police the traffic on the trunk. Could look like this:
2950:
class-map Internet
match access-group name 4Internet
policy-map LimitInternet
class Internet
police 10000000 8192 exceed-action drop
set cos 1
interface range FastEthernet0/1 - 10
switchport access vlan 123
service-policy input LimitInternet
! if you want per user port limits
ip access-list extended 4Internet
deny any 10.0.0.0 0.255.255.255
deny any 172.16.0 0.15.255.255
deny any 192.168.0.0 0.0.255.255
permit any any
Trunk port on other switches:
class-map Internet
match cos 1
class Internet
police 50000000 8192 exceed-action drop
interface FastEthernet0/3
Tell me what you think about it.
Regards, Martin
Hi ,
Pls do test this,
1.Create a L3 vlan and apply the service policy that you have created to this Vlan
2.Configure "mls qos vlan-based" in the physical interface
use it for ref :
http://www.cisco.com/en/US/products/hw/switches/ps5528/products_configuration_guide_chapter09186a00802b7caf.html#wp1324535
and share us the results
regards
vanesh k
From what i collect from the conversation the problem is as below.
Q1) You are trying policing in the LAB on 3560, and you dont see any output on the policy maps.
Q2) You cannot do SVI based policing as you SVI for a vlan is on another switch and the access ports are on another switch. SO you cannot do a match interface for which it requires the SVI to be on the same local switch.
Hopefully the below is useful in your scenario:
Ans 1) The document which you are referring, if you see the last section it clarifies that "show policy-map interface" is not a supported command, and the output displayed should be ignored.(At the moment there arent any commands spefied to verify the individual policers throughput)
Ans 2) Create a Dummy SVI without an IP address, so that you conserve on the IP space, on the local Switch and police closer to the source. As its recommended to police closer to the source.
Use the config as below. to achieve the same. The below config is tested and working on a 3560. You may have to use a external test equipment to test the validity of your policer in the LAB)
HTH-Cheers,
Swaroop
Config for your reference.
-----------O/P from 3560---------
class-map match-all TEST
match input-interface FastEthernet0/9
class-map match-all PAR
match access-group 101
access-list 101 permit ip any any
policy-map CHILD
class CHILD
police 80000 80000 exceed-action drop --> Use parameters right for you
policy-map PARENT
class PARENT
set precedence 0 <--- Since this is Internet Traffic set Prec to 0
service-policy CHILD
mls qos vlan-based
interface Vlan150
service-policy input PAR
Modified Class Naming.
class-map match-all CHILD
class-map match-all PARENT
policy-map CHILD
class CHILD
policy-map PARENT
class PARENT
mls qos vlan-based
interface Vlan150
service-policy input PARENT
thanks for your replies. I found a solution, by changing my test network. Instead of the 3560 as conncetion facing to the 'internet' switch, I used a 3750. (Because it seemed that the 3560 isn't capable to work as I want him to do.) The 'customer' ports remained on the 3560, but the police-map has been extended with an ip access-list as class-map. The (partial) configurations of these two switche is
3750:
mls qos
class-map match-all vlan150
match access-group 115
class-map match-all vlan160
match access-group 116
policy-map to_Inet
class vlan150
police 3000000 300000 exceed-action drop
class vlan160
interface GigabitEthernet1/0/9
service-policy input to_Inet
keepalive 10
speed 100
duplex full
no cdp enable
access-list 115 permit ip any 192.168.150.0 0.0.0.255
access-list 116 permit ip any 192.168.160.0 0.0.0.255
3560:
mls qos
permit any any
match access-group name everythingL2
class-map match-all EveryIP
match access-group name everythingIP
policy-map 1MBits
class EveryMAC
class EveryIP
policy-map 3MBits
class EveryMAC
class EveryIP
service-policy input 4MBits
ip access-list extended everythingIP
permit ip any any
Mark
charlestran
Community Member
2950 Switch connects to 3750ME fa, Port 1, 100Mb
3560 switch connects to 3750ME gi, Port 1, 1 GbE
Is there a way we can simply limit bandwidth and rate at port level on Cisco 3750 access switch to match bandwidth needs from edge switches?
cisco_bantonei
Community Member
Did you ever get a resolution on this? I am also wanting to allocate my bandwidth usage for individual vlans not by service. On my test bed I need to simulate very small pipes, i.e. 128kbps. If you got answers somewhere else, can you please post them here, so the resolution is found here?
