ME-3400 port is error disabled
skrao_mandalapu
I have below log message in switch.
Jul  2 12:38:59.923 IST: %PM-4-ERR_DISABLE: invalid-policy error detected on Fa0/15, putting Fa0/15 in err-disable state
Jul  2 12:38:59.939 IST: pm_start_recover: invalid operErrReason for Fa0/15
Jul  2 12:39:00.946 IST: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/15, changed state to down
Jul  2 12:39:01.944 IST: %LINK-3-UPDOWN: Interface FastEthernet0/15, changed state to down
ME-3400#sh policy-map int fa0/15
FastEthernet0/15
  Service-policy input: Broadband_User
    Class-map: VOIP (match-all)
      0 packets
      Match: access-group name VOIP
      police aggregate voip
      conform: 0 (packets) exceed: 0 (packets)
      NOTE: Policing statistics for a class configured with an aggregate policer are the
      same for all classes in the policy-map configured with the same aggregate policer
    Class-map: class-default (match-any)
      0 packets, 0 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: any
      police aggregate data
      conform: 27796 (packets) exceed: 0 (packets)
  Service-policy output: uni-out
      283252 packets
      Match: any
      Traffic Shaping
        Average Rate Traffic Shaping
        CIR 11111120 (bps)
        Output Queue:
          Max queue-limit default threshold: 48
          Tail Packets Drop: 426
What is the reason for this error?
Siva Kondala Rao
Andre Gustavo Albuquerque
Are you using aggregate policers inside a policy-map?
Did you check http://www.cisco.com/en/US/docs/switches/metro/me3400/software/release/12.2_46_se/command/reference/cli1.html#wp5049553 ?
The purpose of aggregate policer is sharing the same policer among different classes. I guess you are using two different aggregate policers in the same service-policy.
Could you paste the running config excerpt with the policy-map and interface configuration?
Cheers
