10-22-2006 10:38 PM
Greetings,
I'm trying to use MRM, but the "manager" doesn't seem to know it's source address, despite looking like it does.
I've tried multiple source interfaces.
-----------------------------------------ip mrm manager TEST
manager Serial0/0.1 group 225.0.0.1
senders 1
receivers 2
R3#sh ip mrm manager TEST
Manager:TEST/1.0.0.1 is not running
Beacon interval/holdtime/ttl:60/86400/32
Group:225.0.0.1, UDP port test-packet/status-report:16384/65535
Test senders:
5.5.5.5
Test receivers:
1.1.1.1
R3#mrm TEST start
Monitor source address is not configured
???!!!! Another interface (loopback)
Manager:TEST/3.3.3.3 is not running
Beacon interval/holdtime/ttl:5/86400/32
Group:239.0.0.1, UDP port test-packet/status-report:50000/50001
Test senders:
5.5.5.5
Test receivers:
1.1.1.1
R3#mrm TEST start
I've tried this on various 3640s running enterprise 12.3, and a 2500 running 12.2(32). All have the same result.
Solved! Go to Solution.
10-23-2006 04:48 AM
You have missed this command, I believe.
"R1(config-mrm-manager)# receivers 2 sender-list 1"
Although the Cisco IOS CLI parser accepts the command entered without the sender-list access-list keyword-argument pair, this keyword-argument pair is not optional. For an MRM test to work, you must specify the sources that the Test Receiver should monitor using the sender-list keyword and access-list argument.
This should solve the problem.
HTH-Cheers,
Swaroop
[[[ This is a 3600 O/P from Dynamips ]]]
R1#sh ip mrm in
R1#sh ip mrm interface
Interface Address Mode Status
FastEthernet0/0 10.1.1.1 Test-Receiver Up
R1#mrm TEST1 ?
start Start IP MRM test
stop Stop IP MRM test
R1#mrm TEST1 start
R1#mrm TEST1 start
R1#
R1#
R1#sh
00:06:23: IP MRM test 'TEST1' starts ......
% Type "show ?" for a list of subcommands
R1#
R1#
R1#
R1#sh ip mrm manager
Manager:TEST1/10.1.2.1 is running, expire:1d00h
Group:239.1.1.1, UDP port test-packet/status-report:16384/65535
Test senders:
10.1.1.2 /N-Ack
Test receivers:
10.1.2.2 /N-Ack
Test senders:
10.1.1.2 /N-Ack
Test receivers:
10.1.2.2 /N-Ack
R1#
ip mrm manager TEST1
manager FastEthernet1/0 group 239.1.1.1
senders 1
access-list 1 permit 10.1.1.2
access-list 2 permit 10.1.2.2
R1#sh cdp nei
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
S - Switch, H - Host, I - IGMP, r - Repeater
Device ID Local Intrfce Holdtme Capability Platform Port ID
R2 Fas 0/0 135 R 3620 Fas 0/0
R3 Fas 1/0 172 R 3620 Fas 0/0
R1#
R1#
R1#sh ip int brie
Interface IP-Address OK? Method Status Prot
ocol
FastEthernet0/0 10.1.1.1 YES manual up up
FastEthernet1/0 10.1.2.1 YES manual up up
Loopback0 1.1.1.1 YES manual up up
R1#
10-23-2006 04:48 AM
HTH-Cheers,
Swaroop
R1#sh ip mrm in
R1#mrm TEST1 ?
R1#mrm TEST1 start
R1#mrm TEST1 start
R1#
R1#
R1#sh
R1#
R1#
R1#
Test senders:
10.1.1.2 /N-Ack
Test receivers:
10.1.2.2 /N-Ack
Test senders:
10.1.1.2 /N-Ack
Test receivers:
10.1.2.2 /N-Ack
R1#
senders 1
R1#sh cdp nei
R1#
R1#
R1#sh ip int brie
ocol
R1#
