MVPN @ Cisco ASR901
dfranjoso
Does anyone know if the ASR901 supports Multicast VPN (draft rosen), or if it is on the roadmap? On the CCO documentation i have nothing mentioned, so i am assuming it is no supported.
Thanks!
Hello dfranjoso,
MVPN is not supported on ASR901 and won't be supported in future. You should consider another platform for MVPN.
Best regards,
Dmitry Skotnikov
-- Best regards, Dmitry Skotnikov
Hello dfranjoso,
Best regards,
Dmitry Skotnikov
Thanks Dmytro. It seems that even IGMP and PIM it is not supported on the Global Routing Table! Can you confirm this has well? Thanks
Currently multicast is not supported on ASR901 platform and is targeted to support it at the end of 2013.
Best regards,
Dmitry Skotnikov
