QinQ Question
Hi!,
     I have a project were I need an extended LAN to use VMWare Replication but my service provider gives me just One VLAN on a Point-to-Point link (from site A to site B). From my side I have one 3750 on both sides so I was wondering if I can configure QinQ or something like that to pass more than one VLAN over the service provider network.
     If this possible? any configuration example? thanks alot!
kaffa
If your provider is providing a vlan aware service you can stack on your end, everything inside the agreed outer tag (from the providers perspective) will be transported transparently. If its a port based service you can tag however you like as the provider will do the stacking on the NTE regardless of your headers.
Take care of the MTU; it's also higly probable that the provider will use QinQ in it's own network
