Hi Everyone,
I'm wondering if someone may have encountered a similar issue in the past with the following configuration on a ME3600. Below is a description of what I'm currently seeing.
Attached is a topology of what is currently built.
Site A can reach to Site B without any issues in both directions.
Site B can reach to Sites C-D-E without any issues in both directions
Sites C-D-E can reach to Site A
Site A doesn't appear to reach Sites C-D-E correctly
All 5 sites are currently built using a single VLAN and have L3 established.
If I initiate a Source ping from an Internal SVI at Site C to the WAN SVI which terminated at Site A it works
If I initiate a Source ping from an Internal SVI at Site C to the Internal SVI at Site A, it doesn't.
I can however do the reverse and it will work correctly. So from Site A to Site C.
While going through the packet capture, it appears like the failing traffic is being lost along the way
Any thoughts?
Below are the relevant configs.
Switch-B Configs:
interface gig0/12
description To Switch-A (GigE0/12)
switchport trunk allowed vlan 100
switchport mode trunk
spanning-tree bpdufilter enable
interface gig0/23
description To Customer (Site A)
no cdp enable
no lldp transmit
no lldp receive
Switch-A configs (ME3600):
interface gig0/12
description To Switch-B
mtu 9216
switchport trunk allowed vlan none
ethernet dot1ad uni c-port
service instance 100 ethernet
description To Switch-B (VLAN 100)
encapsulation dot1q 100
bridge-domain 100
interface Ten0/1
desc 3rd Party NNI
mtu 9216
service instance 1 ethernet
description To Site-C
encapsulation dot1ad 2101 dot1q 100
rewrite ingress tag pop 1 symmetric
bridge-domain 100
description To Site-D
encapsulation dot1ad 2102 dot1q 100
bridge-domain 100
description To Site-E
encapsulation dot1ad 2103 dot1q 100
bridge-domain 100
interface Ten0/2
description To Site-B
mtu 9216
bridge-domain 100
I know that best practice should be to have a rewrite in place for all the service instances, however when I tried to do that, the End customer lost all connectivity.
Now some of the things I've tried are:
- Remove "ethernet dot1ad uni c-port" on Switch-A GigE0/12
- Add "ethernet dot1ad nni" to Switch-A Ten0/1
- Rebuilt the bridge-domain
- Tried using "rewrite ingress tag pop 2 symmetrical", however the following error message was displayed:
Invalid EFP Config: conflict with existing efp configuration
Invalid EFP config: egress filtering beyond 2nd vlan in packet is not supported
TenGigabitEthernet 0/1 service instance 1: Unable to add to bridge-domain 100
** To note, there is another customer on this same 3rd party network and it is functioning correctly. The only difference is there is no second tag on the encapsulation part. Only the initial dot1ad tag.
All outside interface (IE: WAN interfaces) can all talk to each other with out any issues. Also, as an additional odd behaviour, if a tunnel is built between the Site A - SiteC/D/E, inside traffic works correctly.
Would anyone have any thoughts.
Thanks.
--Dominique
