10-23-2017 10:07 AM - edited 03-01-2019 02:03 PM
if i have a configuration like this one on a PE router (ios XE):
interface GigabitEthernet3
no ip address
negotiation auto
service instance 5 ethernet
encapsulation dot1q 3-5
bridge-domain 200
interface GigabitEthernet6
no ip address
negotiation auto
service instance 1 ethernet
bridge-domain 200
...and i have traffic coming from GE6 encapsulated as VLAN ID 3; even though i've all the VLANs included in the same bridge domain, there is no chance that i can have traffic crossing the VLAN (i.e. for instance, if the destination IP address of a ping is on a VLAN with ID 4 leaving the GE3, and the source of ping is IP address on a VLAN with ID 3 entering the GE6, the ICMP echo reply shouldn't work), right?
What i'm not sure is if i have to introduce the equivalent of command ethernet egress filter strict"(from XR) in XE or the egress checking is already done automatically.
Mario
10-24-2017 09:27 AM
What i' referring to is well explained here below for XR; what i don't know is how XE behave in the same identical scenario...any ideas?
In the egress direction of an AC, suppose there is no rewrite ingress tag pop <> symmetric command that determines the egress VLAN tags. In that case, there is no check in order to ensure that the outgoing frame has the correct VLAN tags according to the encapsulation command.
This is an example configuration:
interface GigabitEthernet0/1/0/3.2 l2transport
encapsulation dot1q 2
interface GigabitEthernet0/1/0/3.3 l2transport
interface GigabitEthernet0/1/0/39.2 l2transport
l2vpn
bridge group customer2
bridge-domain test
In this configuration, note that:
ethernet egress-filter strict
