Hi all
Im working with ncs 520, and Im trying to make QinQ work, this is my actual configuration
bridge-domain 10
interface TenGigabitEthernet0/0/5
no ip address
service instance trunk 10 ethernet
encapsulation dot1q 1-9,11-130
rewrite ingress tag pop 1 symmetric
bridge-domain from-encapsulation
service instance 11 ethernet
encapsulation dot1q 10
bridge-domain 10
service instance 1024 ethernet
encapsulation untagged
l2protocol peer stp
bridge-domain 1024
End
When I can the "rewrite" command is applied all vlans access with no issue but the layer2 protocols are not working. If I remove the "rewrite" commmand all l2 workd but not the vlans.
