Packet Capture ME-3600X-24FS-M‏
akashkumar.r1
hi,
please help me with how to capture packets on ME-3600X-24FS-M‏ switch?
thank you.
maileh
I have this problem too
EduardoRam
thanks
Jason M.
If you want to capture IP traffic you can also try the embedded packet capture. It will allow you to capture right off the switch. It will only work for routed interfaces so if you want to capture L2 traffic then the previously mentioned SPAN options are the way to go.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/epc/command/epc-cr-book/epc-cr-m1.html
