08-19-2012 09:27 PM
Topology
IXIA-----------Juniper PE------------P------------------CiscoME6524 (gig port running Xconnect).
This is with refrence to the above topology, I want to run xconnect from Cisco to juniper. On the same port where I am running xconnect is it possbile to run cfm in up MEP direction. Does this box support up MEP in Eompls port if so could you please guide me the configuration.
Refer to the above link. it shows that this box supports cfm, in CCO I could not find any doccuments relating to configuration of cfm in eompls port of ME6524. normally it has to support up MEP in Eompls port.
Q. Does the Cisco ME 6524 support Ethernet Operations, Administration, and Maintenance (E-OAM) protocols?
08-19-2012 10:42 PM
When refreing to the below link.
Ethernet CFM is an end-to-end per VLAN Ethernet layer OAM protocol that includes proactive connectivity monitoring, fault verification, and fault isolation. End-to-end can be provider-edge-to-provider-edge (PE-to-PE) device or customer-edge-to-customer-edge (CE-to-CE) device. Ethernet CFM, as specified by IEEE 802.1ag, is the standard for Layer 2 ping, Layer 2 traceroute, and end-to-end connectivity check of the Ethernet network.
The switch does not support:
•CFM transparency in VPLS or EoMPLS pseudowires
•Provider-edge E-LMI
•CFM on bridge domains (supported on switchports only)
These sections contain conceptual information about Ethernet CFM:
This seems confusing.
Sudhin Jacob
CCIE R&S,SP#28680
