Shaping on Cisco ME 3600X
tobin_jim
How do you implement a peak shaping QoS policy on the Cisco ME 3600X. My aim to shape a service instance but to allow the shaper to burst over the shape value to a specified amount, if there is available bandwidth on the physical interface, queing any excess traffic.
I am trying to implement the policy below, except with a shape peak instead of average. However, I don't see the peak keyword under the shape command.  I do see the following mentioned in the configuration guide however,"
shape average{target bps | percentvalue}
Enter percent value to set the percentage of interface bandwidth for peak information rate. The range is 0 to 100 percent. The percentage is based on the port operational link speed. Setting the percent to 0 disables shaping.
I am not sure how to use this to implement my requirements.
If there is not a way to do this using shaping, then can I use policing instead?
class-map match-any VRFA
 match service instance ethernet  2121
policy-map PARENT-G012
 class VRFA
  shape average 2000000
   service-policy CHILD-G012
policy-map CHILD-G012
 class NETWORK
  bandwidth percent 2
 class VOICE
  police cir percent 10
   conform-action transmit
   exceed-action drop
  priority
 class APP1
  bandwidth percent 22
 class APP2
  bandwidth percent 24
 class APP3
  bandwidth percent 12
 class APP4
  bandwidth percent 5
 class class-default
  bandwidth percent 25
  random-detect
interface GigabitEthernet0/12
 switchport trunk allowed vlan none
 switchport mode trunk
service-policy output PARENT-G012
 service instance 2121 ethernet
  encapsulation dot1q 2121
  rewrite ingress tag pop 1 symmetric
  bridge-domain 1500
0 Replies 0
