VPLS VFI not coming up
renato.efrati
hi all, i need some advice in configuring vpls, i've the following scenario:
ME3600X = ASR9K = ME3600X
    PE               P/PE          PE
with following config:
ASR9K:
interface Bundle-Ether100
 mtu 9026
 ipv4 address 10.10.30.1 255.255.255.252
interface Bundle-Ether200
 mtu 9026
 ipv4 address 10.10.30.5 255.255.255.252
interface Loopback0
 ipv4 address 10.10.1.1 255.255.255.255
interface MgmtEth0/RSP0/CPU0/0
 ipv4 address 10.37.0.221 255.255.255.0
interface MgmtEth0/RSP0/CPU0/1
 shutdown
interface TenGigE0/0/0/0
 bundle id 100 mode active
 cdp
interface TenGigE0/0/0/1
 cdp
interface TenGigE0/0/0/2
 bundle id 200 mode active
 cdp
interface TenGigE0/0/0/3
 cdp
router ospf 1
 area 0
   priority 255
   priority 255
  interface Loopback0
router bgp 65001
 bgp router-id 10.10.1.1
 address-family ipv4 unicast
 address-family l2vpn vpls-vpws
 neighbor 10.10.1.2
  remote-as 65001
  description *** PE1 ***
  update-source Loopback0
   route-reflector-client
 neighbor 10.10.1.3
  remote-as 65001
  description *** PE2 ***
l2vpn
 pw-class vpls
  encapsulation mpls
   control-word
   transport-mode ethernet
  mac-withdraw
 bridge group TESTBG
  bridge-domain TESTBD
   vfi VPLS_TEST
    vpn-id 100
    autodiscovery bgp
     rd 65001:100
     route-target 65001:100
     signaling-protocol ldp
mpls ldp
 router-id 10.10.1.1
end
ME3600X PE1:
version 15.5
no service pad
platform bfd allow-svi
hostname PE1
no aaa new-model
clock timezone CET 1 0
clock summer-time CEST recurring last Sun Mar 2:00 last Sun Oct 2:00
ip routing
no ip domain lookup
mpls label range 16000 21999
mpls label protocol ldp
l2vpn
 logging pseudowire status
 router-id 10.10.1.2
l2vpn vfi context TEST
 vpn id 100
 autodiscovery bgp signaling ldp
  vpls-id 65001:100
  rd 65001:100
  route-target export 65001:100
  route-target import 65001:100
spanning-tree mode rapid-pvst
license udi pid ME-3600X-24TS-M sn XXXXXXXXX
diagnostic bootup level minimal
bridge-domain 100
 member GigabitEthernet0/1 service-instance 10
 member vfi TEST
transceiver type all
 monitoring
vlan internal allocation policy ascending
vlan 100
pseudowire-class atom
 encapsulation mpls
interface Loopback0
 ip address 10.10.1.2 255.255.255.255
interface Port-channel1
 no switchport
 mtu 9012
 ip address 10.10.30.2 255.255.255.252
 ip ospf priority 0
 mpls ip
interface GigabitEthernet0
 no ip address
 shutdown
 speed auto
 duplex auto
 negotiation auto
interface GigabitEthernet0/1
 description *** Link to CE1 ***
 switchport trunk allowed vlan none
 switchport mode trunk
 service instance 10 ethernet
  encapsulation untagged
  l2protocol forward
interface TenGigabitEthernet0/1
 no switchport
 mtu 9012
 no ip address
 mpls ip
 channel-group 1 mode active
interface TenGigabitEthernet0/2
 no switchport
 mtu 9012
 no ip address
 mpls ip
interface Vlan1
 no ip address
 shutdown
router ospf 1
 network 10.10.1.2 0.0.0.0 area 0
 network 10.10.30.2 0.0.0.0 area 0
router bgp 65001
 bgp router-id 10.10.1.2
 bgp log-neighbor-changes
 no bgp default ipv4-unicast
 neighbor 10.10.1.1 remote-as 65001
 neighbor 10.10.1.1 update-source Loopback0
 address-family ipv4
  neighbor 10.10.1.1 activate
 exit-address-family
  neighbor 10.10.1.1 send-community both
  neighbor 10.10.1.1 prefix-length-size 2
 exit-address-family
ip forward-protocol nd
no ip http server
no ip http secure-server
mpls ldp router-id Loopback0
control-plane
line con 0
line vty 0 4
 login
line vty 5 15
 login
exception crashinfo file flash:crashinfo
ntp server 10.10.1.1
end
ME3600X PE2:
version 15.4
no service pad
hostname PE2
no aaa new-model
ip routing
no ip domain lookup
l2vpn
 router-id 10.10.1.3
 vpn id 100
  vpls-id 65001:100
  rd 65001:100
bridge-domain 100
 member vfi TEST
 monitoring
vlan 100
pseudowire-class mpls
 encapsulation mpls
interface Loopback0
 ip address 10.10.1.3 255.255.255.255
 description *** Link to ASR9K ***
 no switchport
 mtu 9012
 ip address 10.10.30.6 255.255.255.252
 ip ospf priority 0
 mpls ip
 no ip address
 shutdown
 speed auto
 duplex auto
 negotiation auto
 description *** Link to CE2 ***
  encapsulation default
  l2protocol forward
interface GigabitEthernet0/2
 service instance 20 ethernet
 no switchport
 mtu 9012
 no ip address
 mpls ip
 no switchport
 mtu 9012
 no ip address
 mpls ip
interface Vlan1
 no ip address
 shutdown
router ospf 1
 router-id 10.10.1.3
 network 10.10.1.3 0.0.0.0 area 0
 network 10.10.30.6 0.0.0.0 area 0
router bgp 65001
 bgp router-id 10.10.1.3
 address-family ipv4
 exit-address-family
 exit-address-family
no ip http server
control-plane
line con 0
line vty 0 4
 login
line vty 5 15
 login
end
3 Accepted Solutions
renato.efrati
from the following output, you can see that bgp autodiscovery ldp singaling is working( i can see other PE with VFI configured).
but from show vfi it doesnt come up nor even VC....... is there anything that im missing?
another strange behavior is that from ASR9K point of view i'd expected to see labelled frame outgoing from interfaces but it doesnt:
sh mpls forwarding:
Local  Outgoing    Prefix             Outgoing     Next Hop        Bytes
Label  Label       or ID              Interface                    Switched
16000  Pop         10.10.1.2/32       BE100        10.10.30.2      46623
16001  Pop         10.10.1.3/32       BE200        10.10.30.6      46365
seems like it pop out the label....i would expect to see a label swap instead....and a pop on PE......
PE1#
PE1#
PE1#sh mpls l2 vc
Local intf     Local circuit              Dest address    VC ID      Status
VFI TEST       vfi                        10.10.1.1       100        DOWN
VFI TEST       vfi                        10.10.1.3       100        DOWN
PE1#sh mpls l2 vc  det
Local interface: VFI TEST vfi down
  Interworking type is Ethernet
  Destination address: 10.10.1.1, VC ID: 100, VC status: down
    Last error: Local access circuit is not ready for label advertise
    Output interface: none, imposed label stack {}
    Preferred path: not configured
    Default path: no route
    No adjacency
  Create time: 01:06:21, last status change time: 02:18:41
    Last label FSM state change time: 01:06:21
  Signaling protocol: LDP, peer 10.10.1.1:0 up
    Targeted Hello: 10.10.1.2(LDP Id) -> 10.10.1.1, LDP is UP
    Graceful restart: not configured and not enabled
    Non stop routing: not configured and not enabled
    Status TLV support (local/remote)   : enabled/supported
      LDP route watch                   : enabled
      Label/status state machine        : remote ready, LndRru
      Last local dataplane   status rcvd: No fault
      Last BFD dataplane     status rcvd: Not sent
      Last BFD peer monitor  status rcvd: No fault
      Last local AC  circuit status rcvd: DOWN(hard-down, not-ready)
      Last local AC  circuit status sent: No fault
      Last local PW i/f circ status rcvd: No fault
      Last local LDP TLV     status sent: No status
      Last remote LDP TLV    status rcvd: No fault
      Last remote LDP ADJ    status rcvd: No fault
    MPLS VC labels: local unassigned, remote 16002
    Group ID: local unknown, remote n/a
    MTU: local unknown, remote 1500
    Remote interface description: VPLS_TEST
  Sequencing: receive disabled, send disabled
  Control Word: Off (configured: autosense)
  Dataplane:
    SSM segment/switch IDs: 0/0 (used), PWID: 3
  VC statistics:
    transit packet totals: receive 0, send 0
    transit byte totals:   receive 0, send 0
    transit packet drops:  receive 0, seq error 0, send 0
  Destination address: 10.10.1.3, VC ID: 100, VC status: down
    No adjacency
  Create time: 01:06:16, last status change time: 02:18:41
    Last label FSM state change time: 01:06:16
  Signaling protocol: LDP, peer 10.10.1.3:0 up
    Targeted Hello: 10.10.1.2(LDP Id) -> 10.10.1.3, LDP is DOWN, no binding
    Status TLV support (local/remote)   : enabled/None (no remote binding
      Label/status state machine        : ldp ready, LndRnd
      Last local AC  circuit status sent: Not sent
      Last remote LDP TLV    status rcvd: None (no remote binding)
      Last remote LDP ADJ    status rcvd: None (no remote binding)
    MPLS VC labels: local unassigned, remote unassigned
    Group ID: local unknown, remote unknown
    MTU: local unknown, remote unknown
  Dataplane:
    SSM segment/switch IDs: 0/0 (used), PWID: 4
  VC statistics:
PE1#sh vfi
Legend: RT=Route-target, S=Split-horizon, Y=Yes, N=No
VFI name: TEST, state: down, type: multipoint, signaling: LDP
  VPN ID: 100, VPLS-ID: 65001:100
  RD: 65001:100, RT: 65001:100, 65001:100
  Bridge-Domain 100 attachment circuits:
  Neighbors connected via pseudowires:
  Peer Address     VC ID        Discovered Router ID    S
  10.10.1.3        100          10.10.1.3               Y
  10.10.1.1        100          10.10.1.1               Y
PE1#
What is the MTU for the CE facing interface. Is it 1500 or 9012?
Also, are you able to perform a ping from PE to PE sourcing the peering IP, size 9012 and df-bit set To ensure that that packet is able to pass through with the MTU size.
Also, the AC shows hard down. Would like to know if the link is up or not towards the CE. Please share the below output from all PE's:
sh l2vpn bridge-domain bd-name <bd_name> detail
I also see the Targeted Hello is also down - Please perform mpls ping from src to destination.
Also, i see control-word off from the output but you have configured control-word on ASR9k. Any reason for the same?
Last but not the least, in the configuration i see that you have configured the VFI in XE style. The VFI is made member of BD. I think you need to make VFI member configuration directly under SVI rather than under BD. Below is some sample config that you can try:
 l2vpn vfi context Test
 vpn id 100
 autodiscovery bgp signaling ldp template TP-NO-CONTROL-WORD
   vpls-id 1:1
   rd 1:1
   route-target export 1:1
   route-target import 1:1
 template type pseudowire TMP
 encapsulation mpls
 control-word exclude
int gi 0/1
 service instance 100 ethernet
   encapsulation dot1q 100
   service-policy input PM-CUST-DEFAULT-50M-BD-IN
   service-policy output PM-CUST-DEFAULT-50M-OUT
   bridge-domain 100
 Interface Vlan100
 no shut
 vfi member Test
Hope this helps.
Vinit
--Vinit
got it, problem was that me3600x wants a different way to configure vfi membership....
this way works:
interface GigabitEthernet0/3
description Facing CE
logging event link-status
no cdp enable
bridge-domain 100
member GigabitEthernet0/3 service-instance 10
interface vlan 100
no ip address
member vfi TEST
this way doesnt.........
no cdp enable
bridge-domain 100
member vfi management
it seems like you need to configure a SVI(vlan interface) and then tell its to be member of VFI.....
renato.efrati
sh mpls forwarding:
PE1#
PE1#
PE1#sh mpls l2 vc
    No adjacency
  Dataplane:
  VC statistics:
    No adjacency
  Dataplane:
  VC statistics:
PE1#sh vfi
PE1#
 vpn id 100
   vpls-id 1:1
   rd 1:1
 encapsulation mpls
int gi 0/1
   bridge-domain 100
 Interface Vlan100
 no shut
 vfi member Test
Hope this helps.
Vinit
--Vinit
this way works:
no cdp enable
bridge-domain 100
interface vlan 100
no ip address
member vfi TEST
no cdp enable
bridge-domain 100
Thanks for the confirmation. Glad the config worked.
PS; Please mark the question as answered if your issue has been resolved
Vinit
--Vinit
