ASR 900 serial port issue
jspsumit8880
ASR 900 line card 4 0 and 5 0 controller is installed but interface serial is not showing in asr router . Instead of this showing SERIAL-acr and serial-pg
5 Replies 5
M02@rt37
Hello @jspsumit8880
What are the type/name of the line cards ?
Best regards
Type of card E1
Thanks @filopeter
Which RSP is on board ? RSP3C-200-S, 400-S ? RSP2A-64 ?
Thanks.
Best regards
filopeter
Check the RSP Interface Module Compatibility Matrix
https://www.cisco.com/c/en/us/products/collateral/routers/asr-903-series-aggregation-services-routers/datasheet-c78-738338.html
Check also the config guide
https://www.cisco.com/c/en/us/td/docs/routers/asr903/software/guide/chassis/xe-3s/b_Config_Guide_fullbook/b-cfg-t1-e1.html
You need to have the right RSP with the right IOS XE version and you need to set up the card type - either E1 or T1.
