ATOM Cisco 7206VXR (NPE-G2)
mrcomm2000
Dears
I try to configure ATOM in two routers 7206VXR (NPE-G2) with IOS c7200p-advipservicesk9-mz.124-11.T1.bin as the following :
-first router
interface ATM2/0.100 point-to-point
no snmp trap link-status
pvc 0/1234 l2transport
encapsulation aal5
xconnect 10.1.1.1 50 encapsulation mpls
-second router
encapsulation aal5
xconnect 10.1.1.2 50 encapsulation mpls
But vc is down !!!
Local intf Local circuit Dest address VC ID Status
AT2/0.100 ATM AAL5 0/100 10.1.1.1 50 DOWN
I need to know if 7206VXR (NPE-G2) support ATOM configuration or not
I made the same configuration in 2 routers Cisco 7206VXR (NPE-G1) with IOS c7200-js-mz.123-8.T5.bin and vc is up
AT1/0.300 ATM AAL5 2/300 172.21.1.3 300 UP
Please advice
Thank you
15 Replies 15
Harold Ritter
Mohamed,
Could you please include a "show mpls l2 vc detail"
Kindly find attach for show mpls l2 vc detail & show mpls l2 hw-capability
thanks,
Mohamed,
I should have asked for both sides to start with. Can you include the same command for the other PE.
Dear Sir
Find attachments include configuration in two PEs
Mohamed,
Are these two routers directly connected? Can you do a "show mpls ldp bind 172.21.1.40 32" on PE1, a "show mpls ldp bind 172.21.1.30 32" on PE2 and a "show mpls ldp nei" on both.
Dear Sir
Two routers aren't directly connected,
Find attach include show commands
Mohamed,
Could you include the "show mpls ldp bin 172.21.1.40 32" from PE1.
Also include a "show ip route 172.21.1.40" from PE1 and "show ip route 172.21.1.30" from PE2.
Dear Sir
Please check the below informations
PE1#show mpls ldp bin 172.21.1.40 32
tib entry: 172.21.1.40/32, rev 1788
local binding: tag: 717
remote binding: tsr: 172.21.1.1:0, tag: 934
remote binding: tsr: 172.21.1.3:0, tag: 206
remote binding: tsr: 172.21.1.40:0, tag: imp-null
remote binding: tsr: 172.21.1.8:0, tag: 1680
PE1#show ip route 172.21.1.40
Routing entry for 172.21.1.40/32
Known via "ospf 201", distance 110, metric 5, type intra area
Last update from 172.21.2.29 on Serial1/1, 11:49:38 ago
Routing Descriptor Blocks:
* 172.21.2.29, from 172.21.1.40, 11:49:38 ago, via Serial1/1
Route metric is 5, traffic share count is 1
172.21.2.25, from 172.21.1.40, 11:49:38 ago, via Serial1/0
PE2#show ip route 172.21.1.30
Routing entry for 172.21.1.30/32
Last update from 172.21.2.133 on Serial4/1, 11:50:12 ago
172.21.2.133, from 172.21.1.30, 11:50:12 ago, via Serial4/1
* 172.21.2.129, from 172.21.1.30, 11:50:12 ago, via Serial4/0
regards,
not sure if I followed complete thread properly to understand which VC (0/100 or 0/1234?) we are troubleshooting. From some of the outputs PVC, VCID and Remotepeer ID is vs cfgs are different. If its possible pls provide following additional outputs to debug further from both side of PE & do u have ppt/visio topology describing your network?!...
s run
s int atx/y
s mpls l2 vc det
s mpls for detail
s mpls int
ping mpls ipv4 verbose
Turn on following debugs ONLY if its not going to impact your network, if yes then only provide show cmds output and ignore following request:
- debug mpls l2 vc event
- debug mpls l2 sig event
- debug mpls l2 sig fsm
int atmx/y.z
sh
no sh
thanks,
rahul.
Mohamed,
Can you do a "sh ip cef 172.21.1.40" on PE1 and a "show ip cef 172.21.1.30" on PE2.
Mohamed,
I have a feeling the issue is that CEF is not enabled on one of the two PEs, hence me asking for the "show ip cef". That is the only thing I can see that would be causing the VC to stay down even though the labels (IGP and VC labels) are being exhanged properly. Make sure you enable CEF on both PEs.
Hope this helps,
Dear sir
IP CEF enabled in the two routers
PE2#show ip cef 172.21.1.40
172.21.1.40/32, version 11166, epoch 0, per-packet sharing
0 packets, 0 bytes
tag information set, shared
local tag: 717
via 172.21.2.29, Serial1/1, 420 dependencies
traffic share 1
next hop 172.21.2.29, Serial1/1
valid adjacency
tag rewrite with Se1/1, point2point, tags imposed: {934}
via 172.21.2.25, Serial1/0, 426 dependencies
traffic share 1, current path
next hop 172.21.2.25, Serial1/0
valid adjacency
tag rewrite with Se1/0, point2point, tags imposed: {934}
0 packets, 0 bytes switched through the prefix
tmstats: external 0 packets, 0 bytes
internal 0 packets, 0 bytes
PE1#show ip cef 172.21.1.30
172.21.1.30/32, version 822, epoch 0, per-packet sharing
0 packets, 0 bytes
local tag: 54
via 172.21.2.133, Serial4/1, 287 dependencies
next hop 172.21.2.133, Serial4/1
valid adjacency
tag rewrite with Se4/1, point2point, tags imposed: {128}
via 172.21.2.129, Serial4/0, 285 dependencies
traffic share 1
next hop 172.21.2.129, Serial4/0
valid adjacency
tag rewrite with Se4/0, point2point, tags imposed: {128}
regards,
Mohamed,
Interesting. Could you please provide the full config for both PEs.
Hi Mohammed,
Could you try with the advance enterprise feature set.
The "Feature Navigator" tool suggests ATOM" AAL5oMPLS is suggested with either Enterprise or Service Provider feature set.
HTH,
Pankaj
