BFD over iBGP between Cisco Router and Huawei router not peering
wood20011
I am using a Cisco ISR 4331 router to act as a PE (Provide edge) mpls router.
I am also using 2 Huawei NE40 routers as the P routers and also iBGP route reflectors.
Within the MPLS domain I am using ISIS as my IGP.
From an ISIS and iBGP persepctive all is happy between the Cisco PE router and the 2 Huawei NE40 P routers.
I am running BFD over ISIS and the peering has been successful.
When I type in the command on the ISR4331 "show ip route vrf METERING", I see all the BGP updates. This tells me that the Cisco ISR 4331 is rx'ing all the appropiate updates from the Huawei NE40 route reflector.
Pinging all the remote VRF METERING networks has also been successful.
I am also using 2 MPLS-TE tunnels running from the ISR4331 to each of the NE40 routers. If Tunnel 1 fails (goes to NE40_1), I want it to use the FRR (Fast Re-route) feature to swing over to tunnel 2 (goes to NE40_2). The FRR feature is activated based on a iBGP BFD failure.
This is why the iBGP BFD feature is important.
The 2 "show ip bgp neighbors" commands from the ISR4331 below indicate that the iBGP peering is established but the BFD peering is not.
CISCO_MPLS_RTR#show ip bgp neighbors 10.1.2.3
BGP neighbor is 10.1.2.3, remote AS 12316, internal link
Fall over configured for session
BFD is configured. BFD peer is Down. Using BFD to detect fast fallover (multi-hop).
BGP version 4, remote router ID 10.1.2.3
BGP state = Established, up for 2d01h
Last read 00:00:55, last write 00:00:36, hold time is 180, keepalive interval is 60 seconds
Neighbor sessions:
1 active, is not multisession capable (disabled)
CISCO_MPLS_RTR#show ip bgp neighbors 10.1.2.4
BGP neighbor is 10.1.2.4, remote AS 12316, internal link
BGP version 4, remote router ID 10.1.2.4
BGP state = Established, up for 2d02h
Last read 00:00:28, last write 00:00:47, hold time is 180, keepalive interval is 60 seconds
Neighbor sessions:
The ISR4331 config is as follows:-
CISCO_MPLS_RTR#show run
Building configuration...
Current configuration : 4268 bytes
! Last configuration change at 00:13:09 UTC Fri Jan 31 2020
version 15.5
no platform punt-keepalive disable-kernel-core
hostname CISCO_MPLS_RTR
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
no aaa new-model
ip vrf METERING
 description VRF_METERING
 rd 12316:6100
 route-target export 12316:6001
 route-target import 12316:6001
subscriber templating
mpls label protocol ldp
mpls traffic-eng tunnels
license udi pid ISR4351/K9 sn FDO22302P0W
license boot level appxk9
redundancy
 mode none
vlan internal allocation policy ascending
interface Loopback0
 ip address 1.1.1.1 255.255.255.255
 ip router isis 1
interface Tunnel1
 ip unnumbered Loopback0
 mpls ip
 tunnel mode mpls traffic-eng
 tunnel destination 10.1.2.3
 tunnel mpls traffic-eng autoroute announce
 tunnel mpls traffic-eng forwarding-adjacency
 tunnel mpls traffic-eng priority 7 7
 tunnel mpls traffic-eng bandwidth 1000000
 tunnel mpls traffic-eng path-option 1 dynamic
 tunnel mpls traffic-eng record-route
 tunnel mpls traffic-eng fast-reroute bw-protect node-protect
interface Tunnel2
 mpls ip
 tunnel destination 10.1.2.4
interface GigabitEthernet0/0/0
 ip address 192.168.243.1 255.255.255.252
 ip router isis 1
 media-type rj45
 negotiation auto
 mpls ip
 bfd interval 80 min_rx 80 multiplier 3
 isis bfd
 ip rsvp bandwidth percent 100
negotiation auto
interface GigabitEthernet0/0/2.5
 encapsulation dot1Q 50
 ip vrf forwarding METERING
 ip address 172.172.10.1 255.255.255.252
router isis 1
 net 49.0007.0100.6400.9999.00
 metric-style wide
 log-adjacency-changes
 bfd all-interfaces
 mpls traffic-eng router-id Loopback0
 mpls traffic-eng level-1
 mpls traffic-eng level-2
router bgp 12316
 bgp router-id 1.1.1.1
 bgp log-neighbor-changes
 neighbor 10.1.2.3 remote-as 12316
 neighbor 10.1.2.3 update-source Loopback0
 neighbor 10.1.2.3 fall-over bfd
 neighbor 10.1.2.4 remote-as 12316
 neighbor 10.1.2.4 update-source Loopback0
 neighbor 10.1.2.4 fall-over bfd
 address-family ipv4
  neighbor 10.1.2.3 activate
  neighbor 10.1.2.4 activate
 exit-address-family
 address-family vpnv4
  neighbor 10.1.2.3 send-community extended
  neighbor 10.1.2.4 send-community extended
 exit-address-family
 address-family ipv4 vrf METERING
  neighbor 172.172.10.2 remote-as 1234
  neighbor 172.172.10.2 fall-over bfd
  neighbor 172.172.10.2 activate
  neighbor 172.172.10.2 default-originate
 exit-address-family
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
ip rsvp signalling hello bfd
control-plane
line con 0
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 login
end
The BGP setup for the Huawei NE40's are as follows:-
HUAWEI_NE_1 (iBGP route-reflector)
bgp 12316
 router-id 10.1.2.3
 group CISCO internal
 peer CISCO bfd min-tx-interval 100 min-rx-interval 100
 peer CISCO bfd enable
 peer 1.1.1.1 as-number 24316
 peer 1.1.1.1 group CISCO
 peer 1.1.1.1 bfd min-tx-interval 100 min-rx-interval 100
 ipv4-family unicast
  undo synchronization
  peer CISCO enable
  peer 1.1.1.1 enable
 ipv4-family vpnv4
  peer CISCO enable
  peer CISCO reflect-client
  peer CISCO advertise-community
  peer 1.1.1.1 enable
HUAWEI_NE_2 (iBGP route-reflector)
bgp 12316
 router-id 10.1.3.4
 peer CISCO connect-interface LoopBack0
 peer 1.1.1.1 as-number 12316
 ipv4-family unicast
  peer CISCO enable
  peer 1.1.1.1 enable
 ipv4-family vpnv4
  peer CISCO enable
  peer 1.1.1.1 enable
Below are some display commands:-
[HUAWEI_NE_1]dis bgp peer 1.1.1.1 verbose
        BGP Peer is 1.1.1.1,  remote AS 12316
        Type: IBGP link
        BGP version 4, Remote router ID 1.1.1.1
        Update-group ID: 4
        BGP current state: Established, Up for 2d01h15m24s
        BGP current event: KATimerExpired
        BGP last state: OpenConfirm
        BGP Peer Up count: 2
        Received total routes: 0
        Received active routes total: 0
        Advertised total routes: 13
[HUAWEI_NE_1]dis bfd session peer-ip 1.1.1.1
Local Remote     PeerIpAddr      State     Type         InterfaceName
8206  0          1.1.1.1         Down      D_IP_PEER          -
     Total UP/DOWN Session Number : 0/1
Mick
luizfleal_
Do you have any topology for this? Are you using on Cisco as "PE-1", and a huwaei as "PE-2"? Regards;
Thanks for the quick response. The Cisco ISR4331 is 1 of many PE's.  All the other PE's are Huawei AR3260's.
I have attached a PDF document of the map.
I hope this helps.
After trying a fews things, I finally fluked it and got it to work.
On the Cisco 4331 this is what I added:-
bfd map ipv4  10.1.2.3/32  1.1.1.1/32 TEST
bfd map ipv4  10.1.2.4/32  1.1.1.1/32 TEST
bfd-template multi-hop TEST
 interval min-tx 100 min-rx 100 multiplier 3
When I type in:-
#show bfd neighbors
- bfd peering is up
- both bfd is up and bgp is established
