BGP Best Path Selection
josecarvalho
Frequent Visitor
Frequent Visitor
  I know well if we have several paths to the destination, we will BGP Best Path Selection . In which case we were obliged to use BGP Best Path Selection Algorithm?
2 Accepted Solutions
balaji.bandi
check some explanation and use case :
https://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/13753-25.html
BB
Ruben Cocheno
@josecarvalho
Well if you use BGP then BGP Path Selection is applied, so it keep the protocol and routing table stable…..
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
Bgp run best path selection auto' you dont have option to run ot not run best path' but you can make one path attribute more prefer than other.
MHM
balaji.bandi
BB
Ruben Cocheno
@josecarvalho
