04-08-2025 09:59 AM
Hi there !!
I trying to make some test in cisco cml 2.8 with traffic engineer tunnel with explicit patch .
I'm using the the topology in the image below. I have already configure tunnel with explicit path from PE1( PE1-p2-p5-p3-p4-PE3) it is working, that is with IOS XE also I have test some other patch from PE1 and work grate. but I have the problem with PE3(IOS XR) that the tunnels isn't work with explicit path, with dynamic patch work great. I had tried to configure the same patch that the router select on dynamic path in explicit patch but that does not work.
can some see if I'm making a mistake in the configuration ?
or MPLS tunnel doesn't work well on ios XR in cisco cml ?
Topology
Configurations :
PE1
! hostname PE1 ! ! vrf definition test-bgp rd 1000:300 ! address-family ipv4 route-target export 1000:300 route-target import 1000:300 exit-address-family ! vrf definition test-ospf rd 1000:200 ! address-family ipv4 route-target export 1000:200 route-target import 1000:200 exit-address-family ! vrf definition test-static rd 1000:101 ! address-family ipv4 route-target export 1000:101 route-target import 1000:101 exit-address-family ! ! ! ! mpls label range 1000 1099 mpls traffic-eng tunnels multilink bundle-name authenticated l2vpn vfi context test_sign vpn id 15 autodiscovery bgp signaling bgp ve id 11 ve range 50 ! ! bridge-domain 15 member GigabitEthernet4 service-instance 15 member vfi test_sign ! ! interface Loopback1 ip address 11.11.11.11 255.255.255.255 ip ospf 1 area 0 ! interface Loopback2 vrf forwarding test-ospf ip address 12.12.12.12 255.255.255.255 ! interface Tunnel1 ip unnumbered Loopback1 tunnel mode mpls traffic-eng tunnel destination 33.33.33.33 tunnel mpls traffic-eng autoroute announce tunnel mpls traffic-eng path-option 1 explicit name to-pe3-2534 ! interface GigabitEthernet1 ip address 10.100.111.11 255.255.255.0 negotiation auto mpls traffic-eng tunnels no mop enabled no mop sysid ip rsvp bandwidth ! interface GigabitEthernet2 ip address 10.100.112.12 255.255.255.0 negotiation auto mpls traffic-eng tunnels no mop enabled no mop sysid ip rsvp bandwidth ! interface GigabitEthernet3 no ip address negotiation auto no keepalive no mop enabled no mop sysid xconnect 33.33.33.33 10 encapsulation mpls ! interface GigabitEthernet4 vrf forwarding test-bgp ip address 10.200.11.1 255.255.255.252 negotiation auto no mop enabled no mop sysid ! interface BDI15 ip address 192.168.0.3 255.255.255.0 no mop enabled no mop sysid ! router ospf 1 router-id 11.11.11.11 network 10.100.0.0 0.0.0.0 area 0 network 10.100.0.0 0.0.255.255 area 0 mpls ldp sync mpls ldp autoconfig mpls traffic-eng router-id Loopback1 mpls traffic-eng area 0 ! router bgp 1000 bgp router-id interface Loopback1 bgp log-neighbor-changes no bgp default ipv4-unicast neighbor 5.5.5.5 remote-as 1000 neighbor 5.5.5.5 update-source Loopback1 ! address-family ipv4 exit-address-family ! address-family vpnv4 neighbor 5.5.5.5 activate neighbor 5.5.5.5 send-community both exit-address-family ! address-family ipv4 vrf test-bgp neighbor 10.200.11.2 remote-as 1120 neighbor 10.200.11.2 ebgp-multihop 5 neighbor 10.200.11.2 update-source GigabitEthernet4 neighbor 10.200.11.2 activate neighbor 10.200.11.2 as-override exit-address-family ! address-family ipv4 vrf test-ospf network 12.12.12.12 mask 255.255.255.255 exit-address-family ! address-family ipv4 vrf test-static redistribute connected redistribute static exit-address-family ! ip forward-protocol nd no ip http server ip http secure-server ! ip route vrf test-static 10.200.1.1 255.255.255.255 10.200.11.2 ! ! ip explicit-path name to-pe3-2534 enable index 1 next-address 2.2.2.2 index 2 next-address 5.5.5.5 index 3 next-address 3.3.3.3 index 4 next-address 4.4.4.4 index 5 next-address 33.33.33.33 ! ! ! ip prefix-list p1p3-ShamLink seq 5 permit 12.12.12.12/32 ip prefix-list p1p3-ShamLink seq 10 permit 32.32.32.32/32 ! ! route-map p1p3-ShamLink deny 5 description block Ips to be us for sham lik match ip address prefix-list p1p3-ShamLink ! route-map p1p3-ShamLink permit 10 ! mpls ldp router-id Loopback1 force ! ! end
P1
hostname P1 ! ip cef login on-success log no ipv6 cef ! ! ! ! ! ! ! ! mpls label range 100 199 mpls traffic-eng tunnels ! ! ! ! interface Loopback1 ip address 1.1.1.1 255.255.255.255 ip ospf 1 area 0 ! interface Ethernet0/0 ip address 10.100.15.1 255.255.255.0 mpls traffic-eng tunnels ip rsvp bandwidth ! interface Ethernet0/1 ip address 10.100.12.1 255.255.255.0 mpls traffic-eng tunnels ip rsvp bandwidth ! interface Ethernet0/2 ip address 10.100.13.1 255.255.255.0 mpls traffic-eng tunnels ip rsvp bandwidth ! interface Ethernet0/3 ip address 10.100.111.1 255.255.255.0 mpls traffic-eng tunnels ip rsvp bandwidth ! interface Ethernet1/0 ip address 10.100.122.1 255.255.255.0 ! interface Ethernet1/1 no ip address shutdown ! interface Ethernet1/2 no ip address shutdown ! interface Ethernet1/3 no ip address shutdown ! router ospf 1 router-id 1.1.1.1 network 10.100.0.0 0.0.255.255 area 0 mpls ldp sync mpls ldp autoconfig mpls traffic-eng router-id Loopback1 mpls traffic-eng area 0 ! ip forward-protocol nd ! ! ip http server ip http secure-server ip ssh bulk-mode 131072 no logging btrace mpls ldp router-id Loopback1 ! ! ! control-plane ! ! ! line con 0 exec-timeout 0 0 logging synchronous line aux 0 line vty 0 4 exec-timeout 0 0 login transport input ssh ! ! end
P2
hostname P2 ! ! ip cef login on-success log no ipv6 cef ! ! ! mpls label range 200 299 mpls traffic-eng tunnels ! ! interface Loopback1 ip address 2.2.2.2 255.255.255.255 ip ospf 1 area 0 ! interface Ethernet0/0 ip address 10.100.25.2 255.255.255.0 mpls traffic-eng tunnels ip rsvp bandwidth ! interface Ethernet0/1 ip address 10.100.12.2 255.255.255.0 mpls traffic-eng tunnels ip rsvp bandwidth ! interface Ethernet0/2 ip address 10.100.24.2 255.255.255.0 mpls traffic-eng tunnels ip rsvp bandwidth ! interface Ethernet0/3 ip address 10.100.112.2 255.255.255.0 mpls traffic-eng tunnels ip rsvp bandwidth ! router ospf 1 router-id 2.2.2.2 network 10.100.0.0 0.0.255.255 area 0 mpls ldp sync mpls ldp autoconfig mpls traffic-eng router-id Loopback1 mpls traffic-eng area 0 ! ip forward-protocol nd ! mpls ldp router-id Loopback1 ! ! ! end
P3
hostname P3 ! ! mpls label range 300 399 mpls traffic-eng tunnels ! ! interface Loopback1 ip address 3.3.3.3 255.255.255.255 ip ospf 1 area 0 ! interface Ethernet0/0 ip address 10.100.35.3 255.255.255.0 mpls traffic-eng tunnels ip rsvp bandwidth ! interface Ethernet0/1 ip address 10.100.34.3 255.255.255.0 mpls traffic-eng tunnels ip rsvp bandwidth ! interface Ethernet0/2 ip address 10.100.13.3 255.255.255.0 mpls traffic-eng tunnels ip rsvp bandwidth ! interface Ethernet0/3 ip address 10.100.33.3 255.255.255.0 ip ospf network point-to-point mpls traffic-eng tunnels ip rsvp bandwidth ! interface Ethernet1/0 ip address 10.100.32.3 255.255.255.0 ! interface Ethernet1/1 ip address 30.200.11.3 255.255.255.0 ip ospf network point-to-point ip ospf 1 area 0 ! interface Ethernet1/2 no ip address shutdown ! interface Ethernet1/3 no ip address shutdown ! router ospf 1 router-id 3.3.3.3 network 10.100.0.0 0.0.255.255 area 0 mpls ldp sync mpls ldp autoconfig mpls traffic-eng router-id Loopback1 mpls traffic-eng area 0 ! ip forward-protocol nd ! ! ip http server ip http secure-server ip ssh bulk-mode 131072 no logging btrace mpls ldp router-id Loopback1 ! ! end
hostname P4 ! ! ! ip cef login on-success log no ipv6 cef ! ! mpls label range 400 499 mpls traffic-eng tunnels ! ! ! interface Loopback1 ip address 4.4.4.4 255.255.255.255 ip ospf 1 area 0 ! interface Ethernet0/0 ip address 10.100.45.4 255.255.255.0 mpls traffic-eng tunnels ip rsvp bandwidth ! interface Ethernet0/1 ip address 10.100.34.4 255.255.255.0 mpls traffic-eng tunnels ip rsvp bandwidth ! interface Ethernet0/2 ip address 10.100.24.4 255.255.255.0 mpls traffic-eng tunnels ip rsvp bandwidth ! interface Ethernet0/3 ip address 10.100.43.4 255.255.255.0 ip ospf network point-to-point mpls traffic-eng tunnels ip rsvp bandwidth ! router ospf 1 router-id 4.4.4.4 network 10.100.0.0 0.0.255.255 area 0 mpls ldp sync mpls ldp autoconfig mpls traffic-eng router-id Loopback1 mpls traffic-eng area 0 ! mpls ldp router-id Loopback1 ! ! end
P5
hostname P5 ! ! mpls label range 500 599 mpls traffic-eng tunnels ! ! interface Loopback1 ip address 5.5.5.5 255.255.255.255 ip ospf 1 area 0 ! interface Ethernet0/0 ip address 10.100.15.5 255.255.255.0 mpls traffic-eng tunnels ip rsvp bandwidth ! interface Ethernet0/1 ip address 10.100.25.5 255.255.255.0 mpls traffic-eng tunnels ip rsvp bandwidth ! interface Ethernet0/2 ip address 10.100.35.5 255.255.255.0 mpls traffic-eng tunnels ip rsvp bandwidth ! interface Ethernet0/3 ip address 10.100.45.5 255.255.255.0 mpls traffic-eng tunnels ip rsvp bandwidth ! router ospf 1 network 10.100.0.0 0.0.255.255 area 0 mpls ldp sync mpls ldp autoconfig mpls traffic-eng router-id Loopback1 mpls traffic-eng area 0 ! router bgp 1000 bgp router-id interface Loopback1 bgp log-neighbor-changes bgp listen range 33.33.33.33/32 peer-group pe-group bgp listen range 11.11.11.11/32 peer-group pe-group no bgp default ipv4-unicast neighbor pe-group peer-group neighbor pe-group remote-as 1000 neighbor pe-group update-source Loopback1 neighbor 10.10.10.10 remote-as 1000 neighbor 10.10.10.10 update-source Loopback1 neighbor 11.11.55.55 remote-as 1000 neighbor 11.11.55.55 update-source Loopback1 ! address-family ipv4 neighbor 11.11.55.55 activate neighbor 11.11.55.55 next-hop-self all neighbor 11.11.55.55 send-label exit-address-family ! address-family vpnv4 neighbor pe-group activate neighbor pe-group send-community both neighbor pe-group route-reflector-client neighbor pe-group next-hop-self all neighbor 10.10.10.10 activate neighbor 10.10.10.10 send-community both neighbor 10.10.10.10 route-reflector-client neighbor 10.10.10.10 next-hop-self all exit-address-family ! mpls ldp router-id Loopback1 !
PE3
RP/0/RP0/CPU0:PE3#
RP/0/RP0/CPU0:PE3#
RP/0/RP0/CPU0:PE3#show running-config
Tue Apr 8 16:47:39.612 UTC
!! Building configuration...
!! IOS XR Configuration 24.3.1
!! Last configuration change at Tue Apr 8 16:46:28 2025 by cisco
hostname PE3
logging console disable
username cisco
group root-lr
group cisco-support
secret 10 $6$jlA.zA1kD.w1z...$UCqJKaPJn7TYOed7ZW3J8VKTgY4IWP2UAuL7fk7CZfbB4LEVwoRJ9D4zSKVwgr8Am/TeKqqz2tiuKi4ptCHDf.
explicit-path identifier 11
index 1 next-address strict ipv4 unicast 4.4.4.4
index 2 next-address strict ipv4 unicast 3.3.3.3
index 3 next-address strict ipv4 unicast 5.5.5.5
index 4 next-address strict ipv4 unicast 1.1.1.1
index 5 next-address strict ipv4 unicast 11.11.11.11
vrf test-bgp
rd 1000:300
address-family ipv4 unicast
import route-target
1000:300
export route-target
1000:300
vrf test-ospf
rd 1000:200
import route-target
1000:200
export route-target
1000:200
vrf test-static
rd 1000:101
import route-target
1000:101
export route-target
1000:101
line console
exec-timeout 0 0
absolute-timeout 0
session-timeout 0
line default
exec-timeout 0 0
absolute-timeout 0
session-timeout 0
ipv4 prefix-list p1p2-ShamLink
10 permit 12.12.12.12/32
20 permit 32.32.32.32/32
interface Loopback1
ipv4 address 33.33.33.33 255.255.255.255
interface Loopback2
vrf test-ospf
ipv4 address 32.32.32.32 255.255.255.255
interface tunnel-te1
ipv4 unnumbered Loopback1
autoroute announce
destination 11.11.11.11
path-option 1 explicit identifier 11
interface MgmtEth0/RP0/CPU0/0
shutdown
interface GigabitEthernet0/0/0/0
vrf test-bgp
ipv4 address 10.200.32.1 255.255.255.252
interface GigabitEthernet0/0/0/1
shutdown
interface GigabitEthernet0/0/0/2
shutdown
interface GigabitEthernet0/0/0/3
ipv4 address 10.100.33.33 255.255.255.0
interface GigabitEthernet0/0/0/4
ipv4 address 10.100.43.33 255.255.255.0
prefix-set p1p2-ShamLim
12.12.12.12/32,
32.32.32.32/32
end-set
route-policy default-bgp
pass
end-policy
route-policy p1p2-ShamLink
if destination in p1p2-ShamLim then
drop
else
pass
endif
end-policy
router static
vrf test-static
10.200.2.2/32 10.200.32.2
router ospf 1
area 0
mpls ldp sync
mpls ldp auto-config
mpls traffic-eng
interface Loopback1
router bgp 1000
bgp router-id 33.33.33.33
address-family vpnv4 unicast
neighbor 5.5.5.5
remote-as 1000
vrf test-bgp
neighbor 10.200.32.2
remote-as 1120
ebgp-multihop 5
as-override
update-source GigabitEthernet0/0/0/0
route-policy default-bgp in
route-policy default-bgp out
vrf test-ospf
network 32.32.32.32/32
redistribute ospf 20
vrf test-static
redistribute static
rsvp
bandwidth
bandwidth
mpls traffic-eng
mpls ldp
mpls label range table 0 33000 33100
endShow mpls traffic-eng tunnels 1
RP/0/RP0/CPU0:PE3#show mpls traffic-eng tunnels 1
Tue Apr 8 16:49:33.601 UTC
Name: tunnel-te1 Destination: 11.11.11.11 Ifhandle:0x2c
Signalled-Name: PE3_t1
Status:
Admin: up Oper: down Path: not valid Signalling: Down
path option 1, type explicit 11
Last PCALC Error: Tue Apr 8 16:45:39 2025
Info: No path to destination, 11.11.11.11 (reverselink)
G-PID: 0x0800 (derived from egress interface properties)
Bandwidth Requested: 0 kbps CT0
Creation Time: Tue Apr 8 16:43:35 2025 (00:05:58 ago)
Config Parameters:
Source: router ID (default)
Bandwidth: 0 kbps (CT0) Priority: 7 7 Affinity: 0x0/0xffff
Metric Type: TE (global)
Path Selection:
Tiebreaker: Min-fill (default)
Hop-limit: disabled
Cost-limit: disabled
Delay-limit: disabled
Delay-measurement: disabled
Path-invalidation timeout: 10000 msec (default), Action: Tear (default)
AutoRoute: enabled LockDown: disabled Policy class: not set
Forward class: 0 (not enabled)
Forwarding-Adjacency: disabled
Autoroute Destinations: 0
Loadshare: 0 equal loadshares
Load-interval: 300 seconds
Auto-bw: disabled
Auto-Capacity: Disabled:
Self-ping: Disabled
Fast Reroute: Disabled, Protection Desired: None
Path Protection: Not Enabled
BFD Fast Detection: Disabled
Reoptimization after affinity failure: Enabled
Soft Preemption: Disabled
LSP Tunnel 11.11.11.11 1 [10] is signalled, Signaling State: up
Tunnel Name: PE1_t1 Tunnel Role: Tail
InLabel: GigabitEthernet0/0/0/4, implicit-null
Signalling Info:
Src 11.11.11.11 Dst 33.33.33.33, Tun ID 1, Tun Inst 10, Ext ID 11.11.11.11
Router-IDs: upstream 4.4.4.4
local 33.33.33.33
Bandwidth: 0 kbps (CT0) Priority: 7 7 DSTE-class: 0
Soft Preemption: None
SRLGs: not collected
Path Info:
Incoming Address: 10.100.43.33
Incoming:
Explicit Route:
Strict, 10.100.43.33
Strict, 33.33.33.33
Record Route: Disabled
Tspec: avg rate=0 kbits, burst=1000 bytes, peak rate=0 kbits
Session Attributes: Local Prot: Not Set, Node Prot: Not Set, BW Prot: Not Set
Soft Preemption Desired: Not Set
Resv Info: None
Fspec: avg rate=0 kbits, burst=1000 bytes, peak rate=0 kbits
Displayed 1 (of 1) heads, 0 (of 0) midpoints, 1 (of 1) tails
Displayed 0 up, 1 down, 0 recovering, 0 recovered headsTraceroute to PE1
RP/0/RP0/CPU0:PE3#traceroute 11.11.11.11
Tue Apr 8 16:50:52.271 UTC
Tracing the route to 11.11.11.11
1 10.100.33.3 [MPLS: Label 314 Exp 0] 7 msec
10.100.43.4 4 msec 5 msec
2 10.100.13.1 [MPLS: Label 113 Exp 0] 5 msec
10.100.24.2 6 msec
10.100.13.1 4 msec
3 10.100.111.11 26 msec * 5 msec
RP/0/RP0/CPU0:PE3#
Solved! Go to Solution.
04-08-2025 12:19 PM
Hi @heiliger-eliet ,
Make sure you configure all the core interfaces as point-to-point in ospf. It should fix the issue.
04-08-2025 12:19 PM
04-08-2025 08:40 PM
Wao!!!!! it is working now ... thanks a lot @Harold Ritter .
can I ask .... why cor interfaces must be configure as point-to-point ? I haven't read that on documentation that Te tunnel need IGP point to point interfaces.
04-09-2025 07:41 AM
This is not a requirement, but configuring the core links as p2p is considered a best practice in SP networks.
You could get the MPLS TE to work with the interfaces in broadcast mode, but it imposes additional restrictions. For example you would need to use the interface address in the explicit path configuration instead of the router-id.
