BGP EVPN VPWS - Cisco & Juniper - Traffic withdrawn
Jerems
Hi dear community,
I am facing an issue with the following setup :
Ping is not OK for the BGP EVPN VPWS Service (Vlan / EVC 20).
Here is the configuration of the involed PE :
Cisco PE ISR1111:
interface GigabitEthernet0/0/1
 no ip address
 negotiation auto
 service instance 20 ethernet
  encapsulation dot1q 20
l2vpn evpn instance 20 point-to-point
 route-target export 65003:20
 route-target import 65003:20
 no auto-route-target
 vpws context EVPN-12120
  service target 121201 source 121202
  member GigabitEthernet0/0/1 service-instance 20
router bgp 65003
 bgp router-id 10.0.0.21
 bgp log-neighbor-changes
 neighbor 10.0.0.1 remote-as 65003
 neighbor 10.0.0.1 update-source Loopback0
 address-family l2vpn evpn
  neighbor 10.0.0.1 activate
  neighbor 10.0.0.1 send-community both
  neighbor 10.0.0.1 soft-reconfiguration inbound
 exit-address-family
JUNIPER PE SRX300:
set interfaces ge-0/0/5 unit 20 description "vlan l2vpn-test-Evpn-vpws_Bgp_Signaling"
set interfaces ge-0/0/5 unit 20 encapsulation vlan-ccc
set interfaces ge-0/0/5 unit 20 vlan-id 20
set policy-options policy-statement L2Vpn-evpn-12120-Export term from-L2Vpn-evpn-12120 then community add Rt-L2Vpn-evpn-12120
set policy-options policy-statement L2Vpn-evpn-12120-Export term from-L2Vpn-evpn-12120 then accept
set policy-options policy-statement L2Vpn-evpn-12120-Import term from-L2Vpn-evpn-12120 from community Rt-L2Vpn-evpn-12120
set policy-options policy-statement L2Vpn-evpn-12120-Import term from-L2Vpn-evpn-12120 then accept
set policy-options community Rt-L2Vpn-evpn-12120 members target:65003:20
set routing-instances evpn-12120 protocols evpn interface ge-0/0/5.20 vpws-service-id local 121201
set routing-instances evpn-12120 protocols evpn interface ge-0/0/5.20 vpws-service-id remote 121202
set routing-instances evpn-12120 protocols evpn no-control-word
set routing-instances evpn-12120 interface ge-0/0/5.20
set routing-instances evpn-12120 description "BGP EVPN-VPWS"
set routing-instances evpn-12120 instance-type evpn-vpws
set routing-instances evpn-12120 route-distinguisher 10.0.0.1:20
set routing-instances evpn-12120 vrf-import L2Vpn-evpn-12120-Import
set routing-instances evpn-12120 vrf-export L2Vpn-evpn-12120-Export
set protocols bgp group Bgp-Evpn-Signaling type internal
set protocols bgp group Bgp-Evpn-Signaling local-address 10.0.0.1
set protocols bgp group Bgp-Evpn-Signaling family evpn signaling
set protocols bgp group Bgp-Evpn-Signaling neighbor 10.0.0.21
 I can see some drops on the RX side of the Cisco PE :
VC is up but a ping from station A to B does not work.
PING 192.168.20.2 (192.168.20.2) 56(84) bytes of data.
From 192.168.20.1 icmp_seq=1 Destination Host Unreachable
From 192.168.20.1 icmp_seq=2 Destination Host Unreachable
From 192.168.20.1 icmp_seq=3 Destination Host Unreachable
From 192.168.20.1 icmp_seq=5 Destination Host Unreachable
From 192.168.20.1 icmp_seq=8 Destination Host Unreachable
From 192.168.20.1 icmp_seq=11 Destination Host Unreachable
A packet capture on interface Gi0/0/0 on the Cisco PE shows the packet from Host A arriving at the Cisco PE (ARP request) but it does not exit the router on interface Gi0/0/1 towards Host B.
Any idea folks ?
Thanks in advance for your kind help.
Best Regards,
Jerems
43 Replies 43
Giuseppe Larosa
Hello @Jerems ,
what about the MPLS LSPs between PE loopbacks ?
the pseudowire travels within them in the two directions.
check on Cisco side with
show mpls forwarding 10.0.0.1
Edit:
if it is an emulated environment you may be facing some limitations in the data plane.
Hope to help
Giuseppe
Hi @Giuseppe Larosa ,
Thank you so much for the time spent in replying my post.
Here is the output :
Local      Outgoing   Prefix           Bytes Label   Outgoing   Next Hop
Label      Label      or Tunnel Id     Switched      interface
31         299872     10.0.0.1/32      0             Gi0/0/0    192.168.12.49
        MAC/Encaps=14/18, MRU=1600, Label Stack{299872}
        44AA504C70C19077EEA7A1008847 49360000
        No output feature configured
Hello @Jerems ,
the MPLS LSP toward the remote PE looks like fine,
you can try to use ping mpls 10.0.0.1 source loop0
Hope to help
Giuseppe
Hi @Giuseppe Larosa
Interesting point !
This reminds me an interop issue between Nokia and Juniper regarding the implementation of RFC 4379 and 6424.
So as to have correct answers from the Junos Box i had to specify the FEC-Type in the ping Command. It is a known cosmetic & interop issue on MPLS OAM as i was thinking about.
With Fec-type LDP it works fine :
Thanks @Harold Ritter :
https://community.cisco.com/t5/mpls/mpls-ping-between-asr920-and-juniper-mx204/td-p/4294930
when you capture traffic do you see and vlan tag ?
MHM
Jerems
Hi @MHM Cisco World ,
Thank you aswell for your contribution.
Yes i have the vlan tag of ID 20 flowing from the CE towards the Juniper PEs before reaching the Cisco PE where i perform the capture on the backbone interface.
Hello @Jerems ,
the network diagram that you have provided in first post makes me think the two PE nodes are not directly connected , are they directly connected?
if yes the capture with a single level of MPLS label the VC label 20 is fine
Hope to help
Giuseppe
Can you share
Show l2vpn xconnect details
MHM
ChristopheLucas
Hi Jeremie,
In first read I would say : control-word is on on IOS XE by default and your JunOs push it off.
Christophe
Hi @ChristopheLucas ,
Thank you so much for your feedback. Actually i did already play with this parameter on both boxes but nothing changed.
Anyway, I gonna check again.
Thanks and hope that all is fine for you !
Jerems
Ingress and Egress PEs are not directly connected. There is another Juniper box in between.
Jerems
The transport Label is poped on the directly connected Juniper PE (PHP).
Jerems
It is an evpn vpws not a BGP/LDP signaled xconnect.
But i still can share the details of the other services:
