bgp igp synchronization
sachin30720041
Level 6
Level 6
Hello All,
In the case of XE, to enable bgp-igp synchronization we use the 'synchronization' command.
router bgp 1
synchronization
What is the equivalent of  'synchronization' command on XR?
Sachin
Hi @sachin30720041 ,
This command has never been supported on XR. Synchronization doesn't really make sense anyway, as it requires the route to be received via the IGP as well for the route to be considered valid by BGP, which means you basically had to redistribute BGP into the IGP at the edge. That is the reason the default has been change to "no synchronization" for all IOS platforms as well.
