BGP Multi-path without MPLS
moustafa.abdelhady
Community Member
Hello All,
Can the BGP multi-path work without MPLS?
MPLS a way of label switching. as long as you have your VRFs and its RDs and RTs enables and configured properly you can use mp-bgp without mpls
there is a way that ISP and cisco support it for ISP network that dose not have MPLS enabled in its network which it l2tpv3 tunnels
Jaderson Pessoa
*** Rate All Helpful Responses ***
Jaderson Pessoa
MP-iBGP is required within the MPLS/VPN architecture because the BGP update needs to carry more information than just an IPv4 addres. As an exemple, in the case of the Multiprotocol Label Switthing (MPLS) L3 VPN's, the update must communicate the VPN IPV4 address, MPLS label information, and extended or standard BGP communities.
Jaderson Pessoa
So, can it work without MPLS or not?
The practical use case is with MPLS VPN, I am aware of that.
Jaderson Pessoa
