bgp next-hop
sachin30720041
Hello
R1(1.1.1.1)              R2(2.2.2.2)
   \(vrf1)                            /(vrf1)
   PE1--------P------PE2
  /(vrf2)                            \(vrf2)
R3 (3.3.3.3)              R4(4.4.4.4)
There is BGP vpnv4 running between PE1 and PE2.
6.6.6.6(loopback1), 61.61.61.61(loopback2) and 62.62.62.62(loopback3) are the loopbacks on PE2. All 3 loopbacks are advertised in igp. As a result, PE1 has a reachability to all 3 loopbacks.
On PE1, 6.6.6.6 is the next hop for 2.2.2.2 and 4.4.4.4.
I want to configure 61.61.61.61 as the next hop for 2.2.2.2  and 62.62.62.62 as the next hop for 4.4.4.4 on PE1.
So I configured 'bgp next-hop' under vrf1 and vrf2. And restarted the BGP process.
vrf definition vrf1
rd 12:12
address-family ipv4
route-target export 12:12
route-target import 11:11
bgp next-hop Loopback1
exit-address-family
vrf definition vrf2
rd 22:22
address-family ipv4
route-target export 22:22
route-target import 21:21
bgp next-hop Loopback2
exit-address-family
But still, I see 6.6.6.6 as the next hop for 2.2.2.2 and 4.4.4.4.
Am I missing anything?
Sachin
Hi @sachin30720041 ,
This feature is not supported for interAS vpnv4. You need to include R4 in AS3 for it to work.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
8 Replies 8
Harold Ritter
Level 12
Level 12
Is this a typo?
vrf definition vrf1
rd 12:12
address-family ipv4
bgp next-hop Loopback1 <++++++++ according to what you mentioned, this is 6.6.6.6, right?
exit-address-family
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Hi Harold,
Yes, That is a typo.
Correct config is.
vrf definition vrf1
rd 12:12
address-family ipv4
exit-address-family
vrf definition vrf2
rd 22:22
address-family ipv4
bgp next-hop Loopback3
exit-address-family
lo2 and lo3 are in the global table.
Sachin
And just to make sure, the config with the "bgp next-hop" is applied on PE2, right? If so, it should just work. Did you try a "clear bgp vpnv4 uni * soft out"  from PE2 to see if it solves the issue.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Below is the complete configuration.
R1
    R3-----R4
R2
R3 and R4 are PE routers. BGP vpnv4 session is up between R3 and R4.
R1 and R2 are CE routers.
R1
int gi1
ip address 100.10.30.1 255.255.255.0
no sh
int lo0
ip address 1.1.1.1 255.255.255.255
router bgp 1
neighbor 100.10.30.3 remote-as 3
network 1.1.1.1 mask 255.255.255.255
R2
int gi2
ip address 100.20.30.2 255.255.255.0
no sh
int lo0
ip address 2.2.2.2 255.255.255.255
router bgp 2
neighbor 100.20.30.3 remote-as 3
network 2.2.2.2 mask 255.255.255.255
R3
int lo1
ip address 31.31.31.31 255.255.255.255
ip ospf 1 area 0
int lo2
ip address 32.32.32.32 255.255.255.255
ip ospf 1 area 0
vrf def vrf1
rd 31:31
address-family ipv4 uni
route-target export 31:31
route-target import 4:4
bgp next-hop lo1
vrf def vrf2
rd 32:32
route-target export 32:32
bgp next-hop lo2
int gi1
vrf forwarding vrf1
ip address 100.10.30.3 255.255.255.0
no sh
int gi2
vrf forwarding vrf2
ip address 100.20.30.3 255.255.255.0
no sh
int gi3
ip ospf 1 area 0
ip address 100.30.40.3 255.255.255.0
no sh
int lo0
ip ospf 1 area 0
ip address 3.3.3.3 255.255.255.255
router ospf 1
router-id 3.3.3.3
mpls ldp autoconfig
router bgp 3
neighbor 4.4.4.4 remote-as 4
neighbor 4.4.4.4 update-source lo0
neighbor 4.4.4.4 ebgp-multihop 255
address vpnv4 unicast
neighbor 4.4.4.4 activate
address-family ipv4 vrf vrf1
neighbor 100.10.30.1 remote-as 1
address-family ipv4 vrf vrf2
neighbor 100.20.30.2 remote-as 2
R4
vrf def vrf1
rd 4:4
route-target export 4:4
route-target import 32:32
route-target import 31:31
router ospf 1
router-id 4.4.4.4
mpls ldp autoconfig
int gi3
ip ospf 1 area 0
ip address 100.30.40.4 255.255.255.0
no sh
int lo0
ip ospf 1 area 0
ip address 4.4.4.4 255.255.255.255
router bgp 4
neighbor 3.3.3.3 remote-as 3
neighbor 3.3.3.3 update-source lo0
neighbor 3.3.3.3 ebgp-multihop 255
address-family vpnv4 unicast
neighbor 3.3.3.3 activate
After executing " clear bgp vpnv4 unicast *" on R3 and R4, I see the following output on R4
Router#show bgp vpnv4 unicast all
Route Distinguisher: 4:4 (default for vrf vrf1)
*> 1.1.1.1/32              3.3.3.3          0 3 1 i
*> 2.2.2.2/32              3.3.3.3         0 3 2 i
Route Distinguisher: 31:31
Route Distinguisher: 32:32
I am expecting the next hop for 1.1.1.1 should be 31.31.31.31 and the next hop for 2.2.2.2 should be 32.32.32.32.
I am not sure what I am missing.
Sachin
config the Lo with vrf forwarding.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
addition to Mr.Harold suggest, do you config each loopback with it VRF i think it not use loopback as loopback in different vrf or in global.
ntikader
Hi Sachin ,
The VRF  address-family  BGP next hop is  made  to  works for Intra AS  network .
As with inter AS in your setup due to BGP Next Hop attribute for E-BGP  , the next hop will be the E-BGP configured  neighbor (here it is 3.3.3.3).
BGP Nexthop Attribute. The BGP nexthop attribute is the next hop IP address that is going to be used to reach a certain destination.
For EBGP, the next hop is always the IP address of the neighbor specified in the neighbor command.
PE3(config)#vrf definition 2
PE3(config-vrf)#address-family ipv4 unicast
PE3(config-vrf-af)#bgp ?
next-hop Next-hop for the routes of a VRF in the backbone(in backbone we should  normally have intra AS )
PE 3 will send next hop as it's loopback
*Dec 12 03:31:01.100: %BGP_SESSION-5-ADJCHANGE: neighbor 4.4.4.4 VPNv4 Unicast topology base removed from session BGP Notification received
*Dec 12 03:31:01.100: %BGP_SESSION-5-ADJCHANGE: neighbor 4.4.4.4 IPv4 Unicast topology base removed from session BGP Notification received
*Dec 12 03:31:01.922: %BGP-5-ADJCHANGE: neighbor 4.4.4.4 Up
*Dec 12 03:31:01.923: BGP(4): (base) 4.4.4.4 send UPDATE (format) 31:31:1.1.1.1/32, next 3.3.3.3, label 17, metric 0, path 1, extended community RT:31:31
*Dec 12 03:31:01.924: BGP(4): (base) 4.4.4.4 send UPDATE (format) 32:32:2.2.2.2/32, next 3.3.3.3, label 18, metric 0, path 1, extended community RT:32:32
PE4#sh bgp vpnv4 unicast all
BGP table version is 159, local router ID is 4.4.4.4
*> 2.2.2.2/32 3.3.3.3 0 3 1 i
*> 72.72.72.72/32 3.3.3.3 0 0 3 i
P
PE4#sh bgp vpnv4 unicast all nexthops  ---------- as said next hop will be EBGP neighbor
# Paths Nexthop Address
6 3.3.3.3
6 3.3.3.3
6 3.3.3.3
solution---------------------
when i changed PE 4 to AS 3 as simillar to PE 3 you can see the change you need .( Harold has already sugegsted this earlier )
Dec 12 03:39:37.298: %BGP-5-ADJCHANGE: neighbor 4.4.4.4 Up
*Dec 12 03:39:37.300: BGP(4): (base) 4.4.4.4 send UPDATE (format) 31:31:1.1.1.1/32, next 31.31.31.31, label 17, metric 0, path 1, extended community RT:31:31
*Dec 12 03:39:37.300: BGP(4): (base) 4.4.4.4 send UPDATE (format) 32:32:2.2.2.2/32, next 32.32.32.32, label 18, metric 0, path 1, extended community RT:32:32
PE3
router bgp 3
bgp router-id 3.3.3.3
bgp log-neighbor-changes
neighbor 4.4.4.4 remote-as 3
neighbor 4.4.4.4 update-source Loopback0
4 31.31.31.31 ----------- changed
2 32.32.32.32
4 31.31.31.31 ---------- changed
2 32.32.32.32
PE4#sh bgp vpnv4 unicast all 1.1.1.1
BGP routing table entry for 4:4:1.1.1.1/32, version 17
Paths: (1 available, best #1, table vrf1)
Not advertised to any peer
Refresh Epoch 1
1, imported path from 31:31:1.1.1.1/32 (global)
31.31.31.31 (metric 2) (via default) from 3.3.3.3 (3.3.3.3)
Origin IGP, metric 0, localpref 100, valid, internal, best
Extended Community: RT:31:31
mpls labels in/out nolabel/17
rx pathid: 0, tx pathid: 0x0
Updated on Dec 12 2021 03:39:37 UTC
BGP routing table entry for 31:31:1.1.1.1/32, version 14
Paths: (1 available, best #1, no table)
Refresh Epoch 1
