bgp send-label
ar
I am simulating basing bgp send-label functionality.
I have two routers.
R1 <--> R2
-Running ISIS as IGP
-Ibgp peer using loopback
-running bgp with send-label
R1 advertising 1.1.1.1 loopback IP
R2 advertising 2.2.2.2 loopback IP
But there are no labels..
R1#sho ip bgp labels
   Network          Next Hop      In label/Out label
   1.1.1.1/32       0.0.0.0         imp-null/nolabel
   2.2.2.2/32       2.2.2.2         nolabel/imp-null
R1
router bgp 1
 bgp log-neighbor-changes
 neighbor 2.2.2.2 remote-as 1
 neighbor 2.2.2.2 update-source Loopback0
 address-family ipv4
  no synchronization
  network 1.1.1.1 mask 255.255.255.255
  neighbor 2.2.2.2 activate
  neighbor 2.2.2.2 send-label
  no auto-summary
 exit-address-family
R2
router bgp 1
 neighbor 1.1.1.1 remote-as 1
 neighbor 1.1.1.1 update-source Loopback0
 address-family ipv4
  no synchronization
  network 2.2.2.2 mask 255.255.255.255
  neighbor 1.1.1.1 activate
  neighbor 1.1.1.1 send-label
  no auto-summary
 exit-address-family
Any other things I need to consider here?
thanks
medhat elsaeed
actually the labels are here but it has the value of IMPLICIT_NULL
check the output of the show ip bgp x.x.x.x
R1#sh ip bgp 33.33.33.33
BGP routing table entry for 33.33.33.33/32, version 18
Paths: (1 available, best #1, table default)
  Not advertised to any peer
  Local
    3.3.3.3 (metric 3) from 3.3.3.3 (3.3.3.3)
      Origin incomplete, metric 0, localpref 100, valid, internal, best
      mpls labels in/out nolabel/imp-null   ---> This is the label value
Regards.
pabloboscariol
if you're labbing, you can use explicit-null just to see the labels! :)
