BGP
Aneek
what is the significance of traffic engineering in IGP?
I am really not sure where you want to go with that question.
Title is BGP, question about IGP and the tag is "buying recommendation" .. ?
Also the question is a bit broad, you could write a book about that.
What do you need?
Thanks and br
Juls
Sanjeewa Alahakone
Imagine you need to send traffic from point-A to point-Z, IGP (routing protocol) provides reachability information and when a circuit breaks IGP need to re-converge, causing traffic to drop until new routing information is distributed to all nodes.
Traffic Engineering works on "make before break" concept, with help of IGP, TE Tunnels will be pre-signaled, thus convergence is typically (industry-accepted value) under 50ms
Good luck with your studies here is the starting point
https://tools.ietf.org/html/draft-li-mpls-igp-te-00
